There is two bolts that hold the shroud, two that hold the radiator and a couple that go from the core forward through the grill. Toughest part is getting the radiator hoses off. Drain the radiator, take the hoses off at the radiator end, remove the shroud bolts and just let it hang on the back side of the fan. Take the bolts out of the radiator, tilt it toward the engine and lift out. Then after you remove the two a/c hoses (you need a special tool from autozone, it is the same type of tool that removes fuel lines to change the filter) reach behind the grill from the bottom and take the nuts off of the core bolts. now the core lifts right out. the whole job jakes 30-45 minutes.
__________________
Steve Hefner, Bakersfield CA, 1986 F250,4x4,6.9,ATS Turbo,138000 miles.
1997 Explorer EB, 5.0, 2x4, Auto, 153,000 miles.
1989 BII, 4x4, Manual
