Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-02-2008, 11:55 PM
akhunter3 is starting off with a positive reputation.
Question 98 4.6 missing??
Hey guys, trucks been acting weird lately and I was wondering if y'all could help me figure out the problem....
I have a 98' F150 with a 4.6. Recently it has started missing when sitting still in D, R, etc. It does not do this when when in P or N nor when the RPMs is 900ish, only when sitting still with around a 600 RPM.
After it sits there for awhile it will begin to miss a bit, although not in any type of consistant pattern. When the gas is applied at all the problem goes away.
Does anyone have any ideas on what this might be? ANY thoughts/opinions/ideas are welcome
Thanks,
Jon
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-03-2008, 09:45 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
You are idling too low if you're at 600 RPM.
I'd suggest:
1) Cleaning the IAC valve
2) Inspecting for PCV vacuum leaks (although that usually sets a CEL)
3) Replace the fuel and air filters if it's been more than 30K miles
4) Clean the MAF sensor
5) Reset the PCM so it can re-learn idle strategy after doing the above. Remove the 3 or 5A minifuse in the add-on fusebox back in the corner of the engine compartment for 10-15 minutes.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
