front drive shaft
120 degrees? Ouch. From where to where? Just inside the spline of the front drive shaft itself?
I haven't checked out my '07 to know exactly, but I would expect there is only a few thousandths worth of slack between any of the components that wouldn't begin to produce 120 degrees of rotation.
I feel alot of slack when I slow down and then hit the gas before coming to a complete stop. I climbed under the truck on flat ground with it in 2 wheel drive and turned off. The front drive shaft from the transfer case to the diff has alot of turn in it. There is some play down at the axles but most of the slop is between the transfer case and diff. I had it in for the cam phaser and the dealer said they couldn't find any slack!
chrispinator
07-17-2010 03:38 PM
99_F250_SD
11-03-2009 06:36 PM
johnsonacres
09-11-2002 11:09 AM
