removing cooling fan - Ford Truck Enthusiasts Forums
Old 05-02-2008, 05:01 PM
Skoda's Avatar
Skoda Skoda is offline
Skoda is starting off with a positive reputation.
Hey guysIÓm in the middle of taking apart my truck and aving a hard time figuring out how to take off the fan and clutch assembly thats attached to the surpintine. Any info on how to, or articles will be more then appreciatedRegardsSkoda
Old 05-02-2008, 05:54 PM
jgoebel jgoebel is offline
jgoebel is starting off with a positive reputation.
I've some help have to take the belt off use a chainvise grip on the pully with a rage I think it is 1 1/2 wrench on the shaft an turn it counter clock wise an then take four nuts off the clutch an the fan comes off
Old 05-02-2008, 06:19 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
These are the instructions for installing the Cyclone Power Fan. it should help you in removing the stock fan.
Old 05-02-2008, 07:06 PM
Skoda's Avatar
Quote:
thanks for the tip jgoebel
Old 05-02-2008, 07:08 PM
Skoda's Avatar
Quote:
Thanks monsta for a step in the right direction I don`t see a link but I`ll google it from here;-)Rep points for the both of yeaRegardsSkoda
Old 05-03-2008, 01:03 AM
Monsta's Avatar
Holy crap! I forgot to post the link!!
Old 05-07-2008, 09:24 PM
Skoda's Avatar
the fan is proving to be a real PITA I bought the tool made for the job and it broke I have one more idea, if it doesn't work then I'll go out and buy the chain vice grip and so that SOB fan clutch who's boss
but seriously the guy that came up with the idea to mount the fan clutch assembly to the water pump pulley should be beat'n with it
Old 05-08-2008, 09:04 AM
kenneBF250V10's Avatar
kenneBF250V10 kenneBF250V10 is offline
kenneBF250V10 is starting off with a positive reputation.
When I took mine off a couple of years ago a Ford mechanic told me to use a good sharp chisel and place it on the outter edge of the big nut that mounts the fan to the pulley assembly and give the chisel a couple of smacks with a hammer.
I made sure that the chisel got a good bite and smacked it with a hammer and it came loose pretty easily. If I'm not mistaken you have to turn the fan mounting shaft clockwise to unscrew it (could be wrong). That being said, if you are standing in front of the truck you would place your chisel on the right side of the big nut on pulley. You're basically using the chisel as a wrench but the jarring caused by the hammer is what breaks it loose.
It worked for me. Good luck!
P.S. - It doesn't take a BFH, a small ball peen hammer should do the trick.
Old 05-08-2008, 05:40 PM
super 6.8 super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
That big nut is a lh thread isn't it?
Old 05-08-2008, 06:06 PM
It's been a while since I've taken mine off but like I said, I believe you turn it clockwise.
Old 05-10-2008, 07:58 PM
Skoda's Avatar
Got the darn thing off today
took some cord and a monkey wrench to get r done, nope happy about the delay its caused but now I can move forward
To refreash some fellow members memories, it's turned counter clock wise for the next unlucky soul that has to remove it aswell
fan belt: how to replace adamkat22 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 05-05-2014 07:26 AM
fan clutch brandon.edwards 6.0L Power Stroke Diesel 4 03-16-2014 12:24 AM
Is My Fan Clutch Working? Rick_Fury 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-16-2012 08:20 PM
How to test a fan clutch? aerocolorado Aerostar 6 08-30-2002 11:03 AM
FLEX FAN ON POWERSTROKE thecoppercowboy 1999 - 2003 7.3L Power Stroke Diesel 4 05-26-2001 05:41 PM
Tags
01, 2004, 42, 64, coling, cooling, duty, explorer, fan, ford, powerstroke, remove, removing, super, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
