Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-02-2008, 07:27 AM
eckdog is starting off with a positive reputation.
Thumbs up Blown Fuse #17 97 f250 Gas
Hello, Im new to this forum but I love it. I have a recently purchased 97 f250 that I am working the bugs out of. The fuse for the volt gauge and temp gauge seems to blow every other day or so. The only short term solution is to up the gauge and that only lasts a day or so longer. Alt. and battery are good and hold a charge. Anyone have an idea? Is it a voltage regulator? Truck sat idle for a while before I purchased it and it could be a corrosion issue in some connector? Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-02-2008, 12:30 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Which engine? F250 LD or F250HD (they have different wiring circuits)?
Might also have been a critter chewing on wires....
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-02-2008, 12:41 PM
Sorry, its a f250HD. V8 gas. 351cu.in.?
  #4 (permalink)
Old 05-02-2008, 10:28 PM
Hmm...
Pull the steering wheel shrouds and inspect the harness where it comes out of the shifter shaft. Look for frayed wires that might be intermittently shorting to ground.
Steve
__________________
  #5 (permalink)
Old 05-04-2008, 11:40 AM
Thanks Steve, I'll look at it today and let you know. The fuse blew out again this am, it was good when I parked it last night the this morning turned to key and no volt, or temp gauge????
  #6 (permalink)
Old 05-04-2008, 06:06 PM
Well I looked in that area, no frayed wires. Not sure what to do next?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
