Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-02-2008, 07:05 AM
swickg331 is starting off with a positive reputation.
leaking head gasket
Anyone ever had any issues using 70 351W heads on a 302? I just built the engine it ran for maybe 30 seconds and started leaking coolant from driver's side head at the rear of the head. I used fel-pro gaskets and torqued everything to the 302 specs. I'll be pulling the head this weekend to try to find out what went wrong
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-02-2008, 12:24 PM
HemiEater's Avatar
HemiEater is starting off with a positive reputation.
check the little round tubes that line up the heads to the block might be to long.. also if the lower bolt holes go into water you should use thread sealer on the bolts...
  #3 (permalink)
Old 05-06-2008, 05:29 PM
changed the head gaskets this weekend and replaced the locating dowels.
Started the engine and ran it for about 10 seconds before the head gasket on the #8 cylinder blew out once again!! This is going to drive me nuts.
  #4 (permalink)
Old 05-07-2008, 04:07 AM
HemiEater's Avatar
did you have the heads magnafluxed? and milled?
what year 302?
do the lower bolt holes go into water?
did you use thread sealer?
did you replace the freeze plugs on the end of the heads?
what did you torque the bolts to?
  #5 (permalink)
Old 05-07-2008, 12:08 PM
Yes the heads were totally redone. new valves, seals, freeze plugs, springs, shaved, etc...
The block is a 93. Yes I used thread sealer and I torqued the bolts to 70ft lbs.
  #6 (permalink)
Old 05-07-2008, 04:43 PM
HemiEater's Avatar
Did you clean out the bolt holes. I have seen blocks with a bunch of crap in the holes keeping the bolts from making a good torque on the head...
also the 351 head have a different cooling passage then the 302, the intake might not be making a good seal. Can you see right where it is leaking? I use the felpro 1250 gaskets they cover all the sbf cooling passages.
also you want to torque the upper bolts a little more say 15 more pounds.. they are longer
one more thing I thought of, are you using the cork end seals on the intake, they have a tendence of lifting the heads just a little if there is not enough clearance. I use permatex on the end seals...
just trying to help hope I don't sound crazy, this is all chit I have ran into in the past.
  #7 (permalink)
Old 05-12-2008, 05:07 PM
Got the problem fixed....it was man behind wrench (me) had head up ass. I had a heater hose in a vacuum port, which went directly to the #8 cylinder. All back together and running now. Just a little tuning on the carb and I'll be done. Got any tips for dialing in the electric choke? Thanks for the suggestions
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
