Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-02-2008, 07:04 AM
micabeau1 micabeau1 is offline
Garage is empty, add now
micabeau1 is starting off with a positive reputation.
What is there for gas Engines?
Any Bio-fuel?
there is always talk to replace deisel, any for gas?
  #2 (permalink)
Old 05-02-2008, 09:53 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Ethanol, but you need special permits to make your own. You can buy a conversion, you don't need to do anything to your vehicle, just reprogram the computer to inject more fuel, you can get a plug in to do that with.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #3 (permalink)
Old 05-03-2008, 06:42 PM
IceboxFX's Avatar
IceboxFX IceboxFX is offline
IceboxFX is starting off with a positive reputation.
not that ethanol is gonna save you any money.. or the planet.
__________________
97 F-250 Ex Cab 4x4 7.3 PSD
Truck pics
http://inlinethumb39.webshots.com/34...200x200Q85.jpg
  #4 (permalink)
Old 05-03-2008, 08:05 PM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
Check into hydrogen generators. People are starting to put effort into researching the process just like biodiesel.
Here is one link I found:
MagDrive Fuel From H2O - HHO Generators
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #5 (permalink)
Old 05-05-2008, 04:05 PM
it seems like this hho stuff is almost too good to be true. create hydrogen from water?? Is that what this is about?
  #6 (permalink)
Old 05-05-2008, 05:47 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
This is a Diesel forum after all.
Best advice sell the gasser and buy a diesel !!
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 05-06-2008, 10:56 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II MLCRI$I$ II is offline
MLCRI$I$ II is starting off with a positive reputation.
Toyota? SmartCar? Restore a Yugo? BUY A DIESEL AND START COOKING.
__________________
79 Ranchero 500 ( just begging for a diesel... )
00 Excursion Ltd 4WD 7.3
06 F250 SD CC 4WD 6.0
06 Mountaineer V6 AWD
Next to my WIFE, I love my EX the BEST !!!
  #8 (permalink)
Old 05-06-2008, 07:40 PM
looks like i wandered into your realm.
  #9 (permalink)
Old 05-09-2008, 12:38 AM
tr0y tr0y is offline
tr0y is starting off with a positive reputation.
Make Fuel at Home With Portable DIY Refinery | Autopia from Wired.com
__________________
2003 F250 6.0PSD, 4X4, CrewCab, LWB, Airbags, B&W Gooseneck, train horn.
Soon to add 4" turbo back, Guages, and SCT with some tunes, and of course I would bet new headgaskets and studs when the truck tells me it needs them.
  #10 (permalink)
Old 05-09-2008, 02:18 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.
Why did nobody say propane? Oh yeah propane!
  #11 (permalink)
Old 05-09-2008, 06:30 PM
thosfsull thosfsull is offline
thosfsull is starting off with a positive reputation.
frontpage | Permaculture & Alcohol Can Be A Gas
Make your own Fuel
  #12 (permalink)
Old 05-09-2008, 06:35 PM
In Blume's Book above, he claims a Volkswagon TDI was modified to LOWER the compression some and run on alcohol. End result 22% better mileage than when it was on Diesel.
  #13 (permalink)
Old 05-12-2008, 09:48 AM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
only thing i've tried is a 60/40 mix 60 gas 40 e-85 seem to work okay to no ill destruction of my motor... so at the present time gas is 3.58 e-85 2.85 ... equals about $40 bucks saved each week on 100 gallon fill up (and I burn that much) and the sam milage... but if I go over the 60/40 mix milage goes down tried this on 4 differnt vehicles. (dailey trip is 110 miles)
93 ford explorer 4.0
96 chevy astro 4.3 vortec
96 chevy p/u 5.7 vortec
00 explorer 4.0 sohc
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #14 (permalink)
Old 05-12-2008, 04:39 PM
angus angus is offline
angus is starting off with a positive reputation.
Methanol looks interesting. It looks like you need to drill out the jets in the carb, mess with the timing, use an engine with hardened valve seats, and run a catalytic converter (if you don't already have one) to clean up the emissions. Oh yeah, and in cold weather you'll need to start it on gasoline, or rig up a way to warm the alcohol up first. There's probably a good discussion someplace else.
__________________
1957 panel delivery / 1959 M100 flareside / 1960 M100 styleside / 1960 panel delivery
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
