Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-02-2008, 12:50 AM
Dale424 is starting off with a positive reputation.
351 cleveland swap?
I have a 69 Bronco, that I want to swap a 351 cleveland into. I am currently running a 302 bolted to a NP435. Is there anyone out there who has done this swap?
By the way the bronco has a long list of mods including:
Big Bearing 9", 31 spline alloy axles, Detroit locker, Reverse cut Dana 44, Track Lock, 4.56 gears, I already mentioned the NP435 Transmission, 6" long travel suspension by Bent & Twisted 4wheel drive, 2" Body Lift, 37" Toyo MTs, Stock Dana 20 T-Case (for now), Custom 6 pt cage, and power steering out of a 77 Bronco. It wont win any beauty contests, but it a lot of fun to drive. I will get some pictures on here soon.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-02-2008, 03:38 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
Motor mounts bellhousing and flywheel are all the same but I don't know if they fit in early broncos. Interesting swap never seen it done before.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #3 (permalink)
Old 05-02-2008, 09:18 PM
Thanks for the info. I was pretty sure it would bolt up, but I have a feeling I might have to cut out some of the wheel wells, and I might have an issue with the steering linkage, I was just wondering if anybody out there has tried this. I know a guy that had a 460 in an early bronco, so I know it can be done. Its just a matter of how much work, and money it is going to take.
  #4 (permalink)
Old 05-08-2008, 11:45 AM
ProblemChild's Avatar
ProblemChild is starting off with a positive reputation.
I thought I'd join just to help you a bit, I hope. I have a 74 that had 351 C in itat one time. I am petty sure they use the 302 mounts, the bell houseing is the same, not sure about the clutch. They had to notch the power brake booster braket a bit on the bottom so the valve cover would clear. If you want send me a pm and I can probly did up some pictures for you.
  #5 (permalink)
Old 05-18-2008, 09:39 AM
69Bronc's Avatar
69Bronc is starting off with a positive reputation.
Yes, it can be done. 302 mounts work. Go to classicbroncos.com and do a search for a guy named MadGyver. He will tell you all about it.
I am currently working on putting a 400 in mine. Welcome to the 335 dark side!
  #6 (permalink)
Old 05-20-2008, 08:14 AM
BogginBronc is starting off with a positive reputation.
Hey Dale,
I'm running a Cleveland in my 69. Its a direct bolt in but you need a 3 in body lift to clear the driver valve cover and you will need Sanderson street rod headers OR cut and reweld the pass exhaust manifold. Swap out the factory carb link for a BC Broncos throttle cable and it will make your life easier. Its also 90lbs heavier than a "small" block so be sure your suspension is up to it...especially if you have a winch.
Welcome to the dark side....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
