Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-01-2008, 10:52 PM
Jface is starting off with a positive reputation.
Lost pcv valve
I have a 2003 Expedition with an aluminum block. The motor blew out and was replaced about a year ago. Recently the truck started to stall at idle after warm-up. I took it to the shop and they say it is the pcv valve. But they cannot find the correct replacement as they lost or tossed the original a year ago and had it "rigged to get by". The Ford dealership in town did not carry the correct one as the only description I have is that it "threads in". Is there any place I can look to find out what the original set-up was and parts I need to fix this?
  #2 (permalink)
Old 05-02-2008, 12:59 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Welcome to the forum
Is it a 5.4L 2V engine?
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 05-02-2008, 08:09 AM
galaxie641 is starting off with a positive reputation.
I don't know of any that thread in. It is also important to note that only the passenger side gets a PCV valve, the D. side is just plumbed into the intake. IIRC the PCV valves are pretty universal for the modulars no matter what vehicle. Any auto parts store carries them for a few dollars.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #4 (permalink)
Old 05-02-2008, 08:43 AM
OOps. I forgot to state that it is a 4.6L size engine. From what I have researched online, the valve has a little notch to twist in instead of the smooth can design that slides into a grommet. I am not sure if it has a "y" vacuum line or not. I have seen four different types of pcv valves listed for this model year.
  #5 (permalink)
Old 05-03-2008, 10:48 PM
LxMan1's Avatar
It is 1/2 way back the passengerside valve cover and usually has 1 Hose to it.
When I buy an aftermarket PCV valve for my 88 5.0 Mustang, I usually have to remove the plastic double vacuum tree from it since I only have one hose that fits it direct.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
