Stumble on takeoff.
My first thought would be clean the fuel pressure regulator screen. Take the fuel filter out, and look in the little hole on the drivers side of the bowl on the inside with a mirror. You should see a nice shiney screen. If not, take q-tip sticks (no cotton) and gently clean all the crud off of it. That should get you going. If not, check fuel pressure. It's a start.
carp1
11-20-2003 06:54 PM
