Level kit differences
Anybody here running a leveling kit that has done a comparison of
AutoSpring vs BDS vs daystar.
Not really concerned with diff in price of the kits, but rather the way they work, quality, just anything you may know or have heard.
and If they were all priced the same which would you go with and why.
Isn't the daystar kit a polybushing that you have to take apart the coil over assembly to install....?
The AutoSpring kit is extreamly easy... goes ontop of the C/O assembly took 2 hours to install taking my time (from the time I walked out side to start, to the time I was in the truck driving to get it aligned), and it was $80 shipped.
actually this is somewaht correct. the spacer compress's the spring to raise the vehicle so it in turn stiffens the ride. with the stiffer ride there is less opportunity for the suspension to compress and bring the fender closer to the tire which means less opportunity for the tire to kiss the fender. i am just thinking.
i personally have the 2" autospring and am very happy with it. makes the truck sit level unloaded. i am just waiting for th tore to burn out to replace with larger ones.
I installed the 2" BDS kit on my 07 2wd, it has a 3/4 " metal plate that goes on top of spring assy. and a 1" metal spacer that goes on shock that makes spring a little stiffer. But it rides same as stock ride. I have heard of some of the kits w/studs on top of plate rusting off.
Well I was kind of thinking the same thing about the poly/plastic breaking down after a while. On the other hand with BDS being a suspension company making lift kits and all, I find it hard to believe that they dont know what they are doing either. Im sure they have done testing on it.
Im not taking sides right now, just trying to make a educated decision.
I cant find the post but I think Pimprohr had a AS then ended up going with the daystar, and commented that he liked the Daystar better.
The type of rubber that Daystar uses will not brake down or flatten.I purchased Ready Lift over Daystar because it had a higher front end lift. I also felt a little better with steel due to the size and loads I put in my truck. I was very pleased with Daystar with my F250.Daystar has a good customer support and it came in handy because I was not 100% sure on one thing and the walked me through it and the kit worked like they told me.
1. Daystar kit: Dangerous...or can be. It requires you to remove the coil-over, compress the spring and disassemble the coil-over. you then insert the plastic puck and re-assemble. Now your coil-over lenght is longer than designed and can lead to early failure...not to mention change in ride quality
2. Autosprings/NCD/Steel Spacers: you remove the coil-over, bolt the spacer on the top of the coil-over and re-install. Fast, Easy, Safe, and very unintrusive install. The spacer you get just comes down to $$$ you want to spend and what you order. There is NO CHANGE IN RIDE QUALITY
3. Aluminum and Plastic Spacers: Why would a company sell aluminum for a suspension component? Especially since aluminum corrodes with contact with salt and water? And the very thought of using a plastic puck in my suspension...is just unsettling to me.
I personally like the Autosprings spacer. They've been there for a long time, and when there was a problem, they got it fixed quick. The other companies are basically a copy of the AS spacer.
