I just picked up a bunch of 428 stuff on eBay that included a set of Adjustable Rockers ...
While inspecting them I noticed that (1) Rocker Shaft Stand has a 2.5" long Tube coming out at an angle with a very small hole at the bottom ... Only one Stand has this small Tube ...
Anybody out there who can enlighten me as to the reason for this Tube and which Head (right or left) it should be installed on ... ?
__________________ 1968 F250 4x4 410 4spd.
1966 Ferrari 500 Superfast
1966 Ferrari 275 GTB4 - Competezione
I believe it's a Y block stand. They had one stand on each side with a oil tube for return (me tinks) to the lifter valley. Is there a number on the stand??
__________________
68 Mercury Cougar XR7. Sumthin FE under da hood.
I just looked at a picture of the Y-Block Rocker Assemblies you speak of and it is NOT like that ...
I'll try to get a Picture of it tomorrow ...
I wonder if it's from a Lincoln/Mercury Y-block, 317,341,368 ci displacements. The blocks on these motors had the same bore spacing as an Fe and the overall length of the rocker arms shaft assembly is similar to a Fe's as well. We'll see once the picture is uploaded. These motors are pretty neat too with a steel block and crankshaft. My friend is rebuilding a 368 to put into a "32 ford pickup, had the crankshaft tested and wound up with a tensile strength greater than that of a light duty cummins diesel crank.
When you want to put one in a post, click on the 4th line under the image. That will copy the web address to your clipboard; paste it in the post. You first see a line of gobbly-gook that begins and ends with [IMG]. When you post, the image appears.
Could be some sort of oiling mod. Does it look home-brewed? Years ago I saw a Y-block that someone plumbed real special. Copper tubing from low on the block (I think) and through the valve covers...reeeeeaaaaaalllllllll special. LOL
__________________
NO PRIDE-NO SHAME
'74 F-100 4x4: It's ugly, loud and smelly. Those are it's good points!
You cannot see the "Tube" I referred to, but these are certainly for an FE engine.
428CJs used the same valve train as a 410 or any other FE with a hydrauliic cam. The "Y" blocks often had an external oiler for the rockers, at least my 285 horse 312 did, due to the stock system not supplying enough oil. There are no tubes coming off FE rockers.
Dude you totally should have asked permission to use a pict of my truck for online viewing purposes LMAO!!!!
A picture sez a 1000 words, the parts catalog sez it all.
8) C2AZ-6531-B .. Support-Valve Rocker Arm Shaft
Fits: All FE engines, 1958/76
Fits: All FT engines, 1964/78.
I looked at every OHV support from 1952 thru 1979, only the Y blocks use the oiler tube.
I have had aluminum stands with a B9 number. And the LR and MR iron stands I have both have a C2 and C5 casting number on them. So that's why I questioned if there was a number. I'm not knowledgeable on the Y block stuff but I agree those are the only stand I know of with the oil tube in em. Could even be an aftermarket stand of some kind who knows?? I remember seeing a pic somewhere of tubes in the stands. But can't place it and thought it might be a early FE 58 only deal?? Or it's Y block only and I'm just confused which is very possible as well!!! LOL!!!
__________________
When I saw the 1962 part number (C2AZ-6531-B) in the 1949/59 car parts catalog (printed:1964), I did some digging to see if I could find the original 1958 p/n.
All I could find was: C2AZ-6531-B replaced C2AZ-6531-A.
This morning after my brain kicked in, I remembered I had another source.
Ford updates 1000's of part numbers a year...y'all have no idea what a PITA that is.
btw: The parts catalog illustrations does not show an FE support with a tube...I looked at every D support for every engine Ford used from 1952 thru 1979.
Only the Y's had that tube....and....Ford used the same illustrations for years.
Hell, look in the 1990's catalog for brake parts, the rear brake drum diagram is from 1961!
__________________ Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
Very good to know. Thanks for setting me straight on that. I can understand the part number changes. That alone would make you nuts to sort out. Being in the printing bizz I deal with that as well on a somewhat smaller basis. Presses from Japan, Germany, Sweden with translation and language errors. Not to mention part number errors, updates, revisions and changes!!! LOL I can appreciate the madness!! LOL.
Well maybe this guy can post a pic in his gallery to see what he has.
__________________
