Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-01-2008, 06:23 PM
larryejoh is starting off with a positive reputation.
4 speed OD in a 6 cyl
I have given up trying to get an adapter shaft made to fit a 6 cyl adapter housing. Does anyone know a good source for a V8 adapter shaft? Advanced Adapters wants almost $400
  #2 (permalink)
Old 05-01-2008, 09:05 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Which trans are you trying to adapt? Are you needing a stock Bronco V8 adaptor shaft?
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 05-02-2008, 06:28 AM
I'm adapting the toploader 4 speed overdrive with the top cane shifter fronm a 86 F150 to my Dana 20. All of the aftermarket produced conversion shafts are sit up for using a V8 intermediate housing.
  #4 (permalink)
Old 05-02-2008, 11:11 AM
RCrawler's Avatar
Can you use a cut down V8 shaft?
Jason
__________________
  #5 (permalink)
Old 05-02-2008, 02:28 PM
I had planned that at first. But the stock 2wd shaft is tapered down in the location I need the splines. The only other solution I thought of is to cut the shaft and have the 28 spline end rewelded. I am afraid about getting a shop to weld it straight.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
