Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-01-2008, 04:23 PM
HappyJack96 is starting off with a positive reputation.
Rear Axle Noise...could it be....bearings...fluid??
I don't know diddly about transmission components on these trucks...but I have some noise coming from the rear axle...could it be a bearing...and if so WHERE...or could it be Diff fluid?? How do I check that and top it off?? Have the fluid...just want a little guidance, so hopefully I will save a little time on this project.
Thanks!
HappyJACK
  #2 (permalink)
Old 05-01-2008, 05:00 PM
ynevada is starting off with a positive reputation.
what kind of noise?
when does it happen?
under decel, or while speeding up?
__________________
reaperoffroad
  #3 (permalink)
Old 05-02-2008, 09:00 PM
Hi YNEVADA, thanks for the response!!
I can hear it when I am coasting at slow speeds...sounds like metal to metal...OUCH! I know! That isn't good...but what should I tackle first??
  #4 (permalink)
Old 05-05-2008, 01:14 PM
while under throttle its quiet?
might be carrier bearings.
what year and model is the truck? what rear? 9" or d60?
if its got a removeable cover, pop it off, check the oil for heavy shavings.
check if the carrier goes SIDE TO SIDE.
__________________
reaperoffroad
  #5 (permalink)
Old 05-05-2008, 07:09 PM
aurgathor is gaining momentum as a positive member of FTE.
Check the filler plug first -- normally, it has a magnet to catch metal shavings, so you don't necessarily have to take the cover off.
  #6 (permalink)
Old 05-07-2008, 10:55 AM
Is the filler plug on the top side of the diff? My truck has whatever rear end comes standard with a 2000 Excursion 7.3 Diesel...it is not the real low rear end!! It's hard to hear anything coming from it at much speed primarily due to road noise. It may very well be singin' like a sparrow...but I can't hear it that much unless I am off the throttle and coasting under 30mph...
  #7 (permalink)
Old 05-07-2008, 10:57 AM
Thank you guys for responding...this truck has had constant issues since I bought it...so I am through with the dealer service thing...
ANOTHER QUESTION...should the A/C condenser be dripping even when I am NOT using the A/C?? I have the vents on, but NOT on A/C - but I was getting a pretty steady drip behind the right front tire...doesn't seem normal to me!!
  #8 (permalink)
Old 05-12-2008, 02:47 PM
the compressor will cycle on/off whether u have the AC engaged or not.
normal...
__________________
reaperoffroad
  #9 (permalink)
Old 05-13-2008, 02:25 PM
big poppa pump's Avatar
Got milk, NO, diesel
big poppa pump has a good reputation on FTE.big poppa pump has a good reputation on FTE.big poppa pump has a good reputation on FTE.
Just like said above, check you carridge bearing, its where the two drive shafts connect. Metal piece with rubber interior that holds the drive shafts in place. I had to change mine out, got to be pressed out. Good luck.
__________________
Mike 2003 f-250 XLT Superduty CC 7.3 SRW, 156 WB, auto 4x4 373 gears S-B cold air intake w snorkel, WW, CCV Mod, superchips programmer 60,90,110,foil delete,mbrp 4 inch ss T409 cool duals, stock 16s with 285 Yoko,s A-T, Bilsteins, Zoodad Mod, ARE custom cap, Running lights, Cobra 29 cb peaked and tuned with dual firesticks. PAA MEMBER 26#
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
