Hello- 04 expd eddy baure i get this beeping" sound that is constant for about 3-4 minutes and then stops and re-occurs every so often while driving. I have checked all doors, airbag light, parking break, ect. This is driving me nuts. I have no check engine light and when I check with the information center everything checks out OK.
It might be the seat belt reminder but it keeps going for like 8 to 11 beeps then will stop. Wife saids if she hits the wiper button the beeps start again. No DVD
Parking break is all the way up
All doors closed
Seatbelts are fastened
I also get this weird noise from the overhead compartment where the rear AC controls are at, sound like something viberating for a second when the keys are put in the ignition.
The airbag system uses a 5 x 5 warning beep, repeated every 30 minutes, as a backup warning indicator, when the airbag lamp is inoperative and there is an airbag fault.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
If it is the airbag light, I've seen some posts where they were able to replace the LED bulb in there that burned out, but the "recomended" fix is to replace the whole assembly for the airbag light/switch
I would also take a look at the SRS airbag system. Usually only the light will flash or stay on when the SRS detects a problem within the system. However, if the SRS detects that the airbag light bulb is blown, or the circuit to it has a problem, then the SRS will sound a constant tone to warn you of the bad bulb.
The simple way to check it, is to see if the airbag light comes on when you first start the vehicle. If it doesn't, then that's the reason for the tone you're hearing.
Found the problem!!!!!!! My rear hatch was not closed all the way. I closed the door frimly and the beep is gone. Weird though the door ajar never lite for the rear hatch
Thanks for the push in the right direction guys---
How odd I should see this today my exp was doing the exact same beeping all day off and on yesterday. At first I thought it was my cell phone and a missed message warning, but nope, never have found it. So could it really be a bulb out? Never heard that in all the 6 years I have had this and bulbs have gone out before?
Funny...I have an 05, and the door ayar light was on a few weeks ago...after raising my voice a the kids to close their doors...I got off and checked all the doors and tail gate...the light was still on...I was like what the hell!?!? I got off again and rechecked this time I also checked the hatch and found it not closed completely...
Need Help- i was told by the dealer today that my airbag light in my dash is broke. The dealer stated that the light can not be replaced and i must replace the whole cluster. Is this True
04 Exp Eddie Baure 5.4
Replacing the whole cluster? That's a new one on me.
Take the cluster out yourself and just change the bulb.
Here's a pictorial in which it shows how to take the cluster out. Once it's out, give 1/4 turn on the ABS bulb socket and it should come out. The bulb pulls out of the socket. Expedition
