Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-03-2008, 03:22 PM
RJR99SS is starting off with a positive reputation.
Quote:
Originally Posted by jonpfeifer View Post
do do do the compression test it will direct you in the correct direction. don't try and skip steps it is easy to do and tells so much.
Well i dont have a compression gauge...which is sad because i'm a professional mechanic for 10 years and dont have one. But...i ordered all the good stuff for my top end thanks to george w. i'll get all that where i want it, and if i still have the same problem i'll get a compression gauge and go from there. If i burnt a valve or seat...it'd be annoying but not the end of the world, just an excuse to get aussies i guess.
  #17 (permalink)
Old 05-04-2008, 09:32 AM
jonpfeifer is starting off with a positive reputation.
did you check with local parts house they may loan one for little or no cost
  #18 (permalink)
Old 05-06-2008, 07:03 PM
stans is starting off with a positive reputation.
The 400 in my old Torino made the same sort of noise. Turned out to be a burned and leaking exhaust valve.
  #19 (permalink)
Old 05-06-2008, 07:54 PM
Well i re-did the valvetrain today, took my time to adjust everything and make sure it was perfect. I think my method of adjusting the valves was just flat out wrong, i'm positive that was the problem and that i got it right this time.
I fired it up for a minute or so and it sounded a LOT better, no more sputtering or popping. The problem was in the process THIS happened...
http://www.ford-trucks.com/forums/73...ml#post6124377
So...i got another thing to deal with now.
  #20 (permalink)
Old 05-08-2008, 03:33 PM
Alright...so back to square one.
I got everything back together and fired it up. It's running a lot smoother now after i re-did the valves, but i'm getting a backfire out the exhaust still.
It was idling fine for about 2 minutes, then it started doing it again.
So...i'm going to go get a compression gauge tomorrow, but i'm thinking it cant be the compression, otherwise it wouldnt of been idling fine to start with.
Btw, all the gauges i looked at said they have adapters for 14mm and 18mm....what size is the plug hole on the 400s?
  #21 (permalink)
Old 05-08-2008, 03:53 PM
hollenjoe is starting off with a positive reputation.
hmmmm I was gonna say you should check the bore on your spark plug wholes in the head... Ive never seen it happen but could make sense
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #22 (permalink)
Old 05-08-2008, 07:03 PM
Byteme is starting off with a positive reputation.
Quote:
Well, mine are 14 mm (5/8 spark plug hex). 18 mm is for 13/16 hex plugs.
  #23 (permalink)
Old 06-06-2008, 01:10 PM
Nev. Bronco is starting off with a positive reputation.
Ford rebuilders knew it, cut out.
On the 351m/400 on the drivers side, there are 2 plug wires that run side by side from the dist to the plugs. Cant remember if it is the middle 2 or the last 2. Sometimes with timing problems the rotor line up to the cap there is a cross fire of the 2 cylinders and a miss fire if you will. To fix, separate the 2 wires with wire separators or use some wire lume plastic insulators Summit has kits with dif colors. Causes a missing or a pop cut out type thing. Saw it in a Ford rebuild book or Ford manual somewhere a long while back. Sometimes it is a ark over from the wires so close and side by side all the run, just those 2.
__________________
79 Bronco Custom, gone thru. Lifted.
  #24 (permalink)
Old 06-08-2008, 07:59 AM
pmasley's Avatar
Free at Last!
pmasley has a very good reputation on FTE.pmasley has a very good reputation on FTE.pmasley has a very good reputation on FTE.
Bronco is correct, But also look at the distributor. The wires have to run through the top one way only. I know it does not look neat, but get the FORD diagram and follow it exact. It you don't, a crossfire will happen.
__________________
Paul
West Virginia Chapter
2001 F-250 7.3 Powerstroke Super Duty XLT Extended Cab 4X4 6 Speed 3:73
Bridgestone 305/70R16 ATS Tires
Banks Intercooler, tubes and 1999 Turbo Wheel
Steel HPX and CCV Mod
Bully Dog 4" Exhaust and AIS II Air Filter
FTE TEAM MEMBER of 53449
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
