Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 6.2L Boss
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.2L Boss Discuss the upcoming 6.2L V8
Is F-150 Still King?
  #16 (permalink)
Old 08-08-2008, 12:13 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
I'm still wondering why Ford hasn't gone to multiple-displacement ... It would be easy enough with the OHC.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #17 (permalink)
Old 08-08-2008, 12:35 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
Arrow
Quote:
Exactly! I give Dodge and GM some credit for exploring these technologies. With the HEMI...and GM with Hybrid trucks.
My issue with the "Eco-boost" with FORD is that most folks are going to use the twin turbo often. Which in the end...will result in less MPG's and higher maintenance costs. $$$ Having a smaller engine do what a larger displacement engine was designed for...just doesn't make sense in the long run. The components of the smaller "Eco" engine are going to be under more stress...and might result in more failed engines. I guess time will tell...
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #18 (permalink)
Old 08-14-2008, 07:20 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is starting off with a positive reputation.
It is actually more difficult to engineer multiple displacement into an OHC engine than an OHV engine. This is a major reason why GM has kept a lot of their engines OHV. If you look at a Chevy LS with DOD, the mechanism is in the valley under the intake manifold. They basically use an articulated valve lifter. In an OHC design, particularly a multi-valve, there is very little room to house the mechanism to disable the valve. It can be done, but it makes for a very large head. I would imagine it would be almost impossible to add variable displacement to the 3 valve Triton V-10, as the one head has a balance shaft in it.
  #19 (permalink)
Old 08-15-2008, 12:12 AM
Krewat's Avatar
So do it to the other head, and just remove the oil pressure from the lash adjusters, making them basically very weak springs.
__________________
  #20 (permalink)
Old 08-16-2008, 06:33 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Is it really worth it? I have not heard great improvments in mileage, at least on trucks. Would be interested to see how it lasts say 200k miles down the road.
You can call me closed minded but I honestly don't want that "technology" on one of my trucks. As of now I consider it a gimmick to sell more trucks. So many people buy trucks that don't really need them so they want to wring every mpg out of them so they don't pay so much. If you want a truck or larger vehicle you have to pay for it.
  #21 (permalink)
Old 08-24-2008, 10:51 PM
FirstTimeFordGuy FirstTimeFordGuy is offline
FirstTimeFordGuy is starting off with a positive reputation.
Quote:
Originally Posted by sonicblue2003 View Post
6.2 program has been canceled for the time being. Tooling for the heads is already in mexico and the engine plant was ready... they pulled the plug!!!!
I wonder where you are getting your information from?
  #22 (permalink)
Old 08-25-2008, 07:08 PM
V10_Cougar's Avatar
V10_Cougar V10_Cougar is offline
V10_Cougar is starting off with a positive reputation.
biz
Ford has been running Eaton Root Style Blower in the Lightning F150's and Cobra Mustangs for quite a while. I have not heard of one problem. I am sure the Turbo's will be the same.
__________________
1999 FORD F-250, V10 4x4 4.30 LS
6 Inch Lift, 37 Inch Super Swampers, GIBSON Exhaust
1968 Mercury Cougar
Built FORD Tough with Edelbrock Stuff
  #23 (permalink)
Old 08-25-2008, 11:32 PM
biz4two's Avatar
Arrow
Quote:
I hope you are right V10_Cougar.
We all remember the issues the 6.0L PSD has had with its turbo. Plus...folks that are not familiar with turbos are going to get a crash course learning the maintenance with them. Using FULL sync oil...and making sure to let the engine idle a few minutes after a hard run...so not to cause over heating of the twin turbos. I don't know...
biz
__________________
  #24 (permalink)
Old 08-26-2008, 01:09 PM
V10_Cougar's Avatar
biz
Biz,
I hope I am right too.
__________________
1968 Mercury Cougar
  #25 (permalink)
Old 09-01-2008, 01:45 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
The Dodge system actually holds the valves closed in MDS mode to keep from losing power from pumping air in and out of the down cylinders. This way the force of one piston going up and compressing what air is in the cylinder is counteracted by a different deactivated cylinder being forced back down from the compressed air. This way the 4 deactivated cylinders cancel each other out.
I'm not sure how the GM version works.
I think this would be difficult to compact all od this into the OHC heads.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #26 (permalink)
Old 10-13-2008, 10:16 PM
FendrBendr FendrBendr is offline
FendrBendr is starting off with a positive reputation.
If the 6.2 is canceled I am certainly highly disappointed but yet not surprised. I'm hard core Ford and wouldn't have anything else but I believe Ford needs to root out the sissies in their development teams and grow some balls. Why can't they shove a 425 horse v8 into nearly everything they have like Dodge? They pull the plug on all of their best ideas. Always. The concept Lightning was bound to be the best yet! Canceled. The entire SVT team canceled. I understand they have to meet all these government and emissions bullspit, but Dodge still makes crazy stuff, why can't Ford? You can't buy a V8 pickup with over 300hp without spending 60 grand... Get with the program guys!
  #27 (permalink)
Old 10-14-2008, 03:38 PM
Krewat's Avatar
If you haven't noticed, Dodge ain't doing so well either... Could it be the cost of the high-power-output vehicles not selling? Hmm...
__________________
  #28 (permalink)
Old 10-15-2008, 11:13 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
1999 Ford F-150
BURNSTOUGHFORD is starting off with a positive reputation.
We need pneumatic valves like the honda moto GP bikes.... or solenoid actuated valves... more precise and selectable
__________________
99' F-150 Super Cab Step Side
5.4l/4R70W (previously a 4.6l romeo)
CAI,Flowmaster 50 series dual exhaust,Gryphon Tuner with custom tunes (300 bhp est)
900LB AAL, cranked front Torsion Bars =(2in lift)Lariat LE Seats, Alpine cd player/6x9 speakers
2003 Fx4 Rims, 255/75/17 BFG MT KM
  #29 (permalink)
Old 10-28-2008, 03:40 PM
biz4two's Avatar
Arrow
Quote:
IMO...FORD has canceled all this NEW development because it does not have the "cash" to get it done. I was just watching the DOW stock market...and this is what FORD is working with...
52 week high = $8.99/share
52 week low = $1.80/share
Today trading at $2.12/share
That is really low for a company that was doing so well just a few years ago. Currently they are listed as a "moderate sell". As is GM and Dodge...
The American or Big 3 auto industry is in turmoil and FORD is trying to save all the cash it can.
biz
__________________
  #30 (permalink)
Old 10-30-2008, 04:14 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE.
This is a no brainer, only produce what you can sell. If you can only sell 100 rangers, then only build 100 rangers. Keep production inline with profit. It's when you have to eat vehicles you loose out. Also give americans what they want, be it escapes or rangers, the focus or F-150 and mustangs. Build on your success, make whats selling better and more interesting. Ford was just too big and crumbled under it's own weight. It needs to be a leaner, meaner company as they are doing. When you get a capable suv like the escape 4x4 with a 240 hp V-6 getting 26 mpg, your on the right track. We get 24-25 mpg highway with our 4x4 V-6 mariner with only a 4-speed automatic. I know the 6-speeds are getting 26 or better. We get 22.2 local and we just took it to W,Va and it was quit capable for a crossover in the mountains. It's not my jeep, but it wasn't bad at all, plus alot more comfortable. These are the things ford is doing right.
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
2008 mercury mariner 4x4 V-6, automatic.
1987 jeep wrangler, 258, 5-speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
