Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-01-2008, 07:36 AM
mitch01 is starting off with a positive reputation.
anti lock light on 96 F-150 2wd
The dash light came on about a year ago. I replaced the differential sensor and that had no effect. I removed the battery for a week while I painted the truck and afterward the light didn't come back on... About half a year later it came on for no particular reason.. A couple of times it has stayed off for a day. I tried removing battery again and has had no effect. Any ideas?
thanks
Mitch
  #2 (permalink)
Old 05-16-2008, 01:39 AM
bustech81 is starting off with a positive reputation.
under right side of the dash you will find a single wire connector, blk on one side and blk with org on the other. koeo, dissconnect plug and momentarily ground out blk/org wire. abs lamp will blink codes. To clear, turn off key. turn back on and plug back in.
  #3 (permalink)
Old 05-21-2008, 05:25 PM
thanks heard this before but didn't realize there was an easily acccessable connector (thought I would have to pierce the wire's insulation with a needle and ground it). I will look for the connector and read the code.
BTW, I cleaned the contacts under the master cylinder and at the hydraulic valve on the frame under the right fender with no change in symptom.
thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
