spare pcm - Ford Truck Enthusiasts Forums
spare pcm
Old 05-01-2008, 08:12 AM
C350CREW's Avatar
C350CREW C350CREW is offline
C350CREW is starting off with a positive reputation.
spare pcm
tried to do a search on this but could not find what i wanted, dont like the search function, should only give results from the forum you are in when doing the search. anyway, want to get a spare PCM, if i cannot find one to match the tranny i have, can it be reflashed to match mine? also what is the newest program i should have and how do you check the pcm to find which version? any other recomended spares? IDM/CPS? tips on these?
Old 05-01-2008, 08:26 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
Its PCM code and family (DPC)
You can use any code of the same DPC family. Different codes for different reasons. Most are just updates. On a flash of the DPC you can only get the last code of that DPC family.
Bill
Old 05-01-2008, 08:41 AM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
Do a search on car-part.com. It will be under Engine Computer, (97 will be the newest update for a pcm programing) this will pull up a list for ECU (Electronic Control Unit) towards the bottom you will see the listings for the 7.3L. Find the tranny you have (AT or MT) then emmissions (Fed. "std" or Cali. "low") then the highest letter. Example = 1997 Fed. Auto trans. truck = F7TF-12A650-TB will be the newest PCM; F7TF-12A650-TA will the next newest, etc. Hope this helps.
Old 05-01-2008, 08:58 AM
C350CREW's Avatar
helps a little. all this is new to me so type slow and use small words.
but, can i use a pcm from an auto if i have a man, or man if i have auto?
if so do they need reflashed/reprogrammed?
is it a good idea to carry a spare IDM? are there different types of these?
Old 05-01-2008, 09:25 AM
plowhand's Avatar
Playing in the Dirt
PCM = you can use an auto in a manual because it's not shifting anything, but you "can not" use a manual in an auto because there is no shift/torque converter lock up programing. (I found a 1997 PCM for a customer's truck alittle over a year ago on car-part.com for $75) So look around, you might the right one for your truck.
You can have PCM's reflashed but I don't know the limitations on this.
IDM's don't go out very often, "Keep them DRY". I would definitely carry a spare CPS.
Old 05-01-2008, 09:45 AM
C350CREW's Avatar
makes sense. thanks for the info.
so if i pressure wash the engine compartment, covering the IDM would be a good idea?
Old 05-01-2008, 09:53 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
Yes it would or just don't spray it. A little bit of splash will not hurt it but just don't blast it.
Old 05-01-2008, 09:55 AM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Quote:
Use the advanced search function. You can then narrow down the search to only the forum you want to look into.
Old 05-01-2008, 10:04 AM
farmer ford's Avatar
farmer ford farmer ford is offline
farmer ford is starting off with a positive reputation.
looking for the same thing for my ford. and just checked car-parts.com they have tons of them. how do you Know for sure that they are good? or do you just take that chance to save the money?
Old 05-01-2008, 10:47 AM
MADVAN's Avatar
Old 05-01-2008, 02:35 PM
plowhand's Avatar
Playing in the Dirt
Quote:
Ask Questions:
1. Was it pulled from a running vehicle? Has it been out of the weather? If it was pulled from a wrecked vehicle where was the damage?
2. Ask if they will guarantee it to work. Most places will.
3. Look at it before you pay for it. Any signs of damage or water or heat.
Old 05-01-2008, 09:24 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Most salvage yards have a no DOA policy but it gets tricky with electronics. You can buy a PCM and have it flashed if it doesn't match your trans. I would send them to DP-tuner to be flashed and skip Ford. Once I get organized I will have a spare IDM, PCM, UVC and gaskets, Harness repair kit, IPR, ICP..... Ah forget it I am gonna carry a spare truck on a trailer!! that will solve any issues except theft then I have two trucks to replace...... that would not be good!!
Old 05-01-2008, 10:18 PM
tjbeggs's Avatar
PS- DON'T pressure wash the engine! bad things happen or can happen. low pressure only!!
Old 05-01-2008, 10:42 PM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
Quote:
x2 water BAD
Old 05-01-2008, 10:48 PM
tjbeggs's Avatar
Water isn't the problem its the pressure. I was my engine compartment often but the first two times I used the pressure washer and had problems both times. Never had a problem since using the garden hose. Hot water works even better!!
2004 Harley edition F250 spare tire? The Tiger Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 5 04-22-2016 11:19 PM
Spare Tire, to but, or not to buy??? USCG_PA Excursion - King of SUVs 17 02-23-2016 06:12 AM
PCM Upgrade for e99 jhl3 1999 - 2003 7.3L Power Stroke Diesel 31 12-19-2014 10:16 AM
What do you have to do to change PCM? Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 105 12-30-2013 05:36 PM
2006 F250 PCM picture? jameseric 1999 to 2016 Super Duty 7 12-19-2012 07:29 AM
Tags
1997, 4x4, 73, a1997, automatic, diesel, e4od, ecm, ecmpcm, f250, f250hd, f7tf12a650, f7tf12a650ta, f7tf12a650tb, family, ford, install, pcm, powerstroke, reflash, tb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
