Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-30-2008, 08:29 PM
46yblock is starting off with a positive reputation.
Back where I started in 1993
Yeah pretty much. The whole front end is taken down to frame and suspension. Reworked the running boards, taking off the home made rubber covers. One running board was a bitch to get off, since I had welded mounting bolts to its topside, mounted the board, then everything else. There was no easy way to remove it!
The new seat has been mounted and is at the upholseterers. Next is the frontend strengthening, and then the new motor can go in. Front fenders will need repainting also due to birds, and errors in the initial prep before the first painting.
Along the way I would like to determine once and for all if I can set the clutch up to be hydraulic. Also picked up a new 7 in. brake booster and may match it to a corvette type MC (could sell it too). The aluminum radiator is still an objective.
It doesnt ever end. I hope .
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
