Quote:
Originally Posted by thundercoupe
The 5 year mark was 2/14/08. No more warranty. I have been driving he truck as much as possible to see if it will get any better. The sound of the turbo is louder now then when I first got it back on and it seems to have a broader power band as if I have a little more vane movement than it did. But it still doesn't cycle at idle like it used to and it never sounds like a hair dryer anymore. I talked to a tech at a local ford dealer who thinks it is possible I put too much antisieze in it and it's holding the vanes. I think that's possible. When I had the turbo off I also noticed there is a bit of shaft play up and down. Does anybody think that could be related to any of my problems? What is the allowed shaft play measurement?
Glad the new turbo helped - you do not want to drive a long time w/ sticking vanes. One other thing it could be (although it sounds unlikely the more I read your post) is VGT actuator.
VGT Actuator - Clean (carb. Cleaner ONLY) or replace. VGT actuator will cost around $250.
Beside (drivers side) the fuel filter in the engine well. |
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
