Quote:
Originally Posted by 99f350sd
I never had to worry about that. As far as I know for 4x4 there are two rotors and early one and late one. Same with bearings.. Never heard of getting axle numbers..I'm sure it has to do with 2wd and dual rear wheel IT DOES NOT!! and all that. Dana 50 fronts had 2 versions of rotor. IMO
Uh huh...yeah right.
Since I can read a parts catalog, I know that Ford lists 5 different rotors for '99 F250's with 4WD, you obviously do not.
You ougtta look in the 1990/2002 Ford Light Truck Parts Catalog sometime (Section 30 / Page 13)
Ford shows
5 different rotors for 99 F250's with 4WD and
4 different rotors for 99 F350's with 4WD.
2WD's are a snap, because with 2WD, the parts are listed separately under the front rotor Ford basic part number (1102). Takes 10 seconds to find the number.
With 4WD, Ford lists rotors and related parts
ONLY in the front driving axle parts lists, and there are
4 different parts lists that apply to 4WD '99 and later F250/350's.
So...to determine which rotor is correct, the front axle tag number is a must.
If one has the tag, that's just ducky, without it...one has to know ALL that info I typed in post #3, and most ppl when they come to parts counters don't have that info.
Swing by your local dealer, ask the partsguy for a front rotor for a '99 F350 with 4WD. The first thing he's gonna say is.."Do you have the front axle tag number?"
