Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2010 4.4L Ford Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2010 4.4L Ford Diesel Discuss the upcoming 4.4L Ford diesel engine
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-30-2008, 04:31 PM
blizzardND is starting off with a positive reputation.
2010 Ford F-150 4.4L diesel Spied WTF is Urea?
Here is a quick spy shot on the new Jelly burner from Ford.
2010.5 Ford F-150 4.4L diesel-powered mule [Spied]
A couple quick questions...
WTF is urea?
How much does it cost?
How much urea is used per oil change?
What happens when the the little urea low light comes on?
What if my daughter ignores that warning light(like every other dash warning)
Couldn't Ford call this stuff something other than Urea?
Why does Ford have to use this stuff ? Does any body else?
Will the local gas n go stock it when I need a quart?
What is Ford Thinking anyway?
The guys at Toyota are already laughing (they are probably the ones that named this crap that sounds like pus from some sort of STD infliction.)
-blizz
I'm new here because I would really like a 20MPG E-350 as an RV that I can afford to drive.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-30-2008, 06:00 PM
IB Adrian's Avatar
Administrator
IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.IB Adrian has a spectacular reputation.
Some more photos here:
Urea is exactly that, Urea - (NH2)2CO
Its used to break down the NOX emissions that diesels emit, it actually eliminates up to 99% of them...
As for how often you need to fill up the tank, those that are already on sale in europe dont need filling up until the vehicle needs its oil changed.
Its a much better system than the DPF, as you don't need to "regenerate" it, as such fuel economy is much better.
__________________
Adrian
International chapter
ATWOT is coming... http://www.atwot.com/
MIDATLANTIC REGIONAL MEET ALL TRUCK NATIONALS CARLISLE, PA AUGUST 8--10, 2008 INFO HERE!
  #3 (permalink)
Old 04-30-2008, 06:03 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
Look how far the front bumper is sticking out. Is urea going to be used instead of a dpf filter? Or are they going to be used together?
__________________
-Josh
04 F150 4.6l 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights
85 Bronco 5.8l 351w 4wd Gas Guzzler
  #4 (permalink)
Old 04-30-2008, 06:29 PM
origcharger is gaining momentum as a positive member of FTE.
I don't believe the DPFs are going away.
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #5 (permalink)
Old 05-01-2008, 09:36 PM
PowerStrokeHD has a good reputation on FTE.PowerStrokeHD has a good reputation on FTE.PowerStrokeHD has a good reputation on FTE.
Quote:
Correct, the DPF will be used in conjunction with SCR (urea).
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
  #6 (permalink)
Old 05-02-2008, 01:06 AM
mnmwhit is starting off with a positive reputation.
I'm ready for one NOW in the EXPY
__________________
Max W
06 F-350 4X4 6.0 PSD NORTH POLE, ALASKA
Mobil-1 5-40 turbo diesel truck oil from day #1
98 gallon transfer flow tank
Leer topper insulated
MBRP SS409 turbo back Off-Road duel exhaust-CAT IS GONE
AstroStart 2-way Auto start
Go Rhino pushbar/brushguard,4-9" Lite-Force moose lites
  #7 (permalink)
Old 05-02-2008, 06:27 AM
F350-6's Avatar
Slow Typing
F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.F350-6 has a great reputation on FTE.
So will the reduction in NOX have any effect on particulates? Maybe less work for the DPF resulting in fewer regens, or am I just dreaming again?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 255,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
  #8 (permalink)
Old 05-04-2008, 12:54 PM
Lead Head is gaining momentum as a positive member of FTE.
These SCRs reduce NOX and other gaseous emissions, you will need the DPF to filter out particulates, so your regens will still be there.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #9 (permalink)
Old 05-05-2008, 08:21 PM
herman391's Avatar
herman391 is gaining momentum as a positive member of FTE.
Quote:
Hopefully not as often though. From what I'm hearing this regen thing isn't all that great.
__________________
Steve-AKA herman391
  #10 (permalink)
Old 05-07-2008, 12:05 PM
pullinair's Avatar
pullinair is starting off with a positive reputation.
09 VW TDI's are equiped with this set -up. Ford should have went this direction with the 6.4. Hindsight is always 20/20. It looks to be the best way to go. I cant wait for Ford to bebut this truck with some common sense engineering. I am subscribed.
__________________
Tim
1999.5 6-speed F-350 181,000miles. DP 20tow, highidle, 60 tow, 80 econo. Wicked Wheel, Wastegate adjusted, 6637, 4" dp 5 inch exhuast. Isspro Guages,
  #11 (permalink)
Old 05-07-2008, 04:54 PM
REDFORDFX4 is starting off with a positive reputation.
Diesel
I saw on Edmunds web site they have info on the new gm diesel. Sounds pretty similar to Fords but no mention of the use of urea just regen cycles.
  #12 (permalink)
Old 05-09-2008, 09:34 PM
aldridgec's Avatar
aldridgec is gaining momentum as a positive member of FTE.
I remember reading a few years ago when the "Bluetec" systems from Mercedes were being review that Fed regulations had issues with the SCR system because it required user intervention, meaning if the tank went empty it wouldn't meet the requirements anymore. I think there was debate as to whether it counted as a maintenance item as plugs/wires/filters would be considered, or a user responsibility.
__________________
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #13 (permalink)
Old 05-19-2008, 12:10 PM
IABill is starting off with a positive reputation.
Question
How are they going to keep the stuff from freezing overnight when it gets cold out?????
__________________
02 F-250 4X4 CC,HPSSX, 6637, straight pipe & prediator on tow tune, 93 E-350 Class C motorhome 7.3 Hypermax turbo kit 11,980 gvw
  #14 (permalink)
Old 05-19-2008, 02:29 PM
TXHillCountry's Avatar
Aggie Network
TXHillCountry is starting off with a positive reputation.
Quote:
If it's like Mercedes "AdBlue" mixture of 1/3 Urea and 2/3 water, it'll need an on-board heating system for temps below 14 degrees F.
Although I have heard about a solution that also incorporates a small amount of ethanol, thus pretty much eliminating the freezing issue.
TX
__________________
  #15 (permalink)
Old 06-12-2008, 06:45 AM
rob_nc is gaining momentum as a positive member of FTE.
Quote:
I'm on the Heavy Duty Diesel side of things, but the technology is the same. We are going to use urea based SCR for NOx reduction, but the huge advantage is this... The amount of EGR into the engine can be reduced thereby increasing fuel economy. The resulting higher engine-out NOx is taken care of by the SCR. Also, since the engine-out exhaust gas is NOx rich, the dpf will be able to regen in the passive mode more effectively since soot oxidizes at a lower temperature in a NO2 rich environment than an O2 rich environment.
From 2010 on, all diesel powered vehicles will be required to use OBDII. When your urea tank runs out, it will derate your engine. This is a strategy being forced upon us by the EPA. If you think filling the tank with water will override this, think again. NOx sensors on the outlet of the SCR will monitor NOx levels. If the levels are higher than normal, the system will try to inject more urea to counter this. If this doesn't work, the engine will be forced into derate.
Not all OEMs will use urea. There are other technologies such as the NOx absorber catalyst that Dodge uses with the CTD. However, this system needs to be regenerated the same as a dpf which means more fuel consumption. Others may choose to use massive EGR. Again, the side effect of this is reduced fuel economy. The more you cool the combustion chamber, the more fuel you will need to make power.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
