Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #16 (permalink)
Old 06-12-2008, 07:56 AM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
Originally Posted by rob_nc View Post
I'm on the Heavy Duty Diesel side of things, but the technology is the same. We are going to use urea based SCR for NOx reduction, but the huge advantage is this... The amount of EGR into the engine can be reduced thereby increasing fuel economy. The resulting higher engine-out NOx is taken care of by the SCR. Also, since the engine-out exhaust gas is NOx rich, the dpf will be able to regen in the passive mode more effectively since soot oxidizes at a lower temperature in a NO2 rich environment than an O2 rich environment.
From 2010 on, all diesel powered vehicles will be required to use OBDII. When your urea tank runs out, it will derate your engine. This is a strategy being forced upon us by the EPA. If you think filling the tank with water will override this, think again. NOx sensors on the outlet of the SCR will monitor NOx levels. If the levels are higher than normal, the system will try to inject more urea to counter this. If this doesn't work, the engine will be forced into derate.
Not all OEMs will use urea. There are other technologies such as the NOx absorber catalyst that Dodge uses with the CTD. However, this system needs to be regenerated the same as a dpf which means more fuel consumption. Others may choose to use massive EGR. Again, the side effect of this is reduced fuel economy. The more you cool the combustion chamber, the more fuel you will need to make power.
What's EGR worth? 1 - 2 MPG maybe? And you're saying we'll see a partial gain back from that. It also sounds like the DPF economy reductions may be reduced somewhat which is also good. Will the SCR have any negative affects on MPG? If it does nothing but improve fuel efficiency I don't know why they wouldn't be rushing this to market now.
If I were to run out of urea, could I just pee in the tank?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 305,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #17 (permalink)
Old 06-12-2008, 12:15 PM
rob_nc rob_nc is offline
rob_nc is gaining momentum as a positive member of FTE.
That's the joke I keep telling drivers of my test trucks. The SCR will have no negative affects on fuel economy. One of the reasons we haven't seen this technology yet is due to the lack of a distribution infrastructure for the urea. Since OTR trucks will also be using it, this problem will change for the better.
  #18 (permalink)
Old 06-12-2008, 01:50 PM
F350-6's Avatar
Slow Typing
What's the current cost of urea? How much does your container hold, and how long does that tank last?
__________________
Chris
  #19 (permalink)
Old 06-12-2008, 08:52 PM
Right now, urea is high since it all has to be imported. As soon as the domestic manufacturing/distribution channels are set up, the price will come down. Our tanks are 20 gallons (OTR trucks) and are good for approx. 5000-6000 miles between fill ups depending on fuel consumption.
  #20 (permalink)
Old 06-12-2008, 09:07 PM
F350-6's Avatar
Slow Typing
So how hard is it to produce urea? Are there any NIMBY concerns? Isn't urea also used in fertilizer which has gone up 500% in the last couple of years?
I guess instead of asking about miles per gallon, I should have asked about total cost per gallon.
__________________
Chris
  #21 (permalink)
Old 06-13-2008, 01:03 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
Redneck-Cowboy is starting off with a positive reputation.
I never understood the regen process (well I get it, but as far as emissions go). Tell me this, we went from a average 16mpg 6.0 to a 10mpg 6.4 which ford claims is b/c of the emissions/regen, ok fine, but... there is still some pollution coming out no matter what, so if were injecting the extra amount of fuel to bring us down 6mpg it still gets burnt one way or another, so if that didn't make any sense to you let me put it this way, more fuel, more emissions....right? I wonder how much ahead it really comes out. Back when gas engines first got air pumps (the extra oxygen helps burn up some gases) but in a matter of speaking you could put a giant air pump on any motor/exhaust system and pass any emissions test b/c the parts per million would be way down b/c there is so much more O2.
EGR on the other hand was a good idea, that does work. I know Ford's going to Urea to try and get there fuel milage up to get ahead of Dodge and GM for a short time. I did have an International engineer tell me that "diesel engines are going through what gas engines had to in the 80's, so were trying anything we can to make the new emissions standards", he had also mentioned that dodge is gonna be way behind here in about 2 years b/c they've been basically paying the fine to get the below par (emissions wise) diesels out there, Ford and GM on the other hand are putting all there efforts into finding a cure, maybe dodge is smarter to pay and let ford and GM do all the work and then steal it when they figure it out.
I'm a little weary of Ford making there own diesel myself. I have to work on all there gas engines and they don't think a lot of there engineering through sometimes....most of the time. I just really hope they don't screw this up. I wonder what the comp ratio is on that little engine to make that kinda HP, they better not be blowing the heads off of them like the duramaxs did.
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
  #22 (permalink)
Old 06-13-2008, 01:30 AM
rollerstud98 rollerstud98 is online now
rollerstud98 is starting off with a positive reputation.
more fuel but less harmful emissions, thats the big thing with the DPF's, don't like it but thats the idea with it, although my dads 6.4 gets the same mileage as my 6.0
  #23 (permalink)
Old 06-13-2008, 08:24 AM
Redneck,
Apparently, the Intl. engineer you spoke to didn't know his @ss from a hole in the ground. The CTD in the current Dodge Ram is already 2010 compliant. They do this by using a NOx absorber catalyst. Cummins pushed Dodge to do this because for every Dodge that is sold with the CTD, Cummins gets emissions credits to use toward their big-bore engines. It is because of these credits, that the ISX won't use SCR for 2010.
  #24 (permalink)
Old 06-13-2008, 04:08 PM
Rob_nc
When did dodge get CTD? I had talked to the engineer this winter, I don't pay all that much attention to dodge and chevy, so that's just what I heard. I do however know IH wants to get away from ford the first chance they get, it's kinda weird, like to rival gang members that have no idea who each other are but know they hate each other, lol. When we had both the ford and IH engineers at the shop it looked awful tense between em, they were playin the blame game on a 6.4 we had in that was knockin. The ford engineer mentioned something of Dodge going to Urea at the time.
__________________
Redneck-Cowboy
  #25 (permalink)
Old 06-13-2008, 06:14 PM
Dodge has had the CTD (Cummins Turbo Diesel) for quite awhile now. A variation of it was even in the old body style.
  #26 (permalink)
Old 06-13-2008, 06:59 PM
Lol, I know, my bad, I thought CTD was some sort of acronym for there style of diesel emissions, lol, wow.... ok, well I'll rephrase my question to: when and how did they become 2010 compliment?
__________________
Redneck-Cowboy
  #27 (permalink)
Old 06-13-2008, 10:36 PM
They became 2010 compliant as of 1/1/07. They use a NOx absorber catalyst to bring the NOx levels down to 2010 levels. The disadvantage to an absorber catalyst is it also needs to be regenerated. I'm sure it is being regenerated at the same time the dpf is, but it's still not an economical solution. They also have a finite lifespan and will have to be replaced at some point. I'm sure this point is never mentioned to a future Dodge buyer.
  #28 (permalink)
Old 06-14-2008, 06:36 PM
REDFORDFX4 REDFORDFX4 is online now
2004 Ford F-150
REDFORDFX4 is starting off with a positive reputation.
Seen on edmunds.com on Wed. Ford's Mark Feilds said the clean diesel is coming to the F150 and expedition. But that was it and also talked about hybrids coming later and will need help from goverment on getting everthing approved for those.
  #29 (permalink)
Old 06-16-2008, 09:31 PM
DanielsSoot DanielsSoot is offline
DanielsSoot is starting off with a positive reputation.
20% better fuel economy means around 19mpg right? With the price difference between diesel and gas, plus what ever the urine costs will it be worth it? Bet that's gonna be an expensive add-on too.
I'd like to see them go for one with just 200hp but getting 30mpg. Slow going when towing but fine otherwise. Did'nt all big trucks put out like 200hp 15 years ago? We got by then.
  #30 (permalink)
Old 06-18-2008, 01:47 AM
78bigbronco's Avatar
78bigbronco 78bigbronco is online now
78bigbronco is starting off with a positive reputation.
Interesting thing it seems like the new diesel tech closely matches the technology that powerplants been using for some time, specifically coal plants because of the waste they put out. They have used particulate filters of course, but also SCR (selective catalyst reduction) that uses ammonia injected into the flue gasses in the scrubbers. They make ammonia from urea since huge quantities of ammonia is dangerous to ship and handle. I wonder how similar these systems are. Sensors monitor NOx and and if levels get to high powerplants have to derate, same thing as SO3/4 (sulfer oxides) and sometimes its not a minor derate, we have to bring the powerplants offline if they cant get back within federal limits. This has even efected them economically, as any derate effects prices as well as having to make up the power with more costly units. Also for SCR's to work they have to maintain a higher output, if its the middle of the night and power demand is low the units with SCRs on cannot go to minimum as the SCRs require certain temperatures, so that costs us more money. Just a little tidbit from the power co.
__________________
09 F-350 V10 4x4 6spd CC/8' ordered 5/26/09 delivered 7/6/09
99 F-150 4x4 Reg/Short bed
78 Big Bronco 4x4 (a work in progress)
84 Tbird (351W project still in dry dock)
Tags
150 , 2010 , 250 , 2919 , 44 , 44l , bluetec , diesel , dodge , drain , f150 , ford , mpg , oil , plug , urea
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
