Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-30-2008, 11:45 AM
Cheshire Cat's Avatar
Cheshire Cat is starting off with a positive reputation.
5.0 Efi Q?
I'm looking to go fuel injection on my EB.
I was just wondering what cars are the best to pick up the parts i need.
I have access to alot of late 80's - early 90's Lincons and Mercs fullsize.
Are these good cars to get the parts i need to go EFI or do i need to find a Mustang set up? I have also heard there is a speed density set up or a mass air flow set up. Mass air flow is better right? I know this is a commen upgrade i just haven't done one myself yet. SO any help would be great.
thanks.
__________________
1969 i think. Has a '74 glove box, 302, 3 speed on the floor, f150 springs up front, 2in lift leafs rear, 1966 Mustang 302, c4. Both under construction..
  #2 (permalink)
Old 04-30-2008, 01:36 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Some of those Lincoln's may have SEFI 5.0HO motors in them, if so this is what you want. Grab everything you can, computer, complete engine wiring harness, air ducting and filter box, sensors, vacuum lines, solenoids.. anything you see on the motor that's not on your carb'd motor. Don't forget the O2 sensors in the exhaust system.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #3 (permalink)
Old 04-30-2008, 11:13 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
The Lincoln LSC from 86-92 will have the same HO version of the 5.0 that was in the Mustangs.
Most Lincolns and full size Mercury's will have the standard 5.0. I believe that they are all batch fire, speed density systems. They will make good EFI canidates if you don't plan on any engine mods. The easy way to tell the difference between a standard and a HO engine is the firing order. The standard 5.0 will have the same 1-5-4 firing order as the early 302. The HO's have the 351W 1-3-7 firing order.
In stock form, there is not much difference between a SD system and a MAF system. Both will give you good performance. I've found that the speed density systems tend to have better idle characteristics. If you plan on engine mods such as better heads, intake, cam, or a major displacement increase, you want a Mass Air Flow system. You can also convert your SD to MAF with aftermarket kits available.
If you do a search for fuel injection in this forum, you should come up with quite a bit of information. If you're really serious about a swap and learning about Ford EFI systems, this is the book to get Barnes*&*Noble.com - Books: Ford Fuel Injection and Electronic Engine Control, by Charles O. Probst, Paperback
It has a lot of useful information including some wiring diagrams. Great book. I've worn mine out.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 05-01-2008, 11:30 AM
thanks guys that is the kind of info i was looking for. Lincoln's of that era are easy to find in my area and usualy are left alone in the junk yards.
Jason, I will have to check out that book. I'm always looking for good info.
I was wondering also, dose anyone make a braket for the clutch linkage to install a newer rollor block into a eb? I'm been told and looked for myself that the block dosen't have the clutch linkage mounting. But, i would like to find a car and just take everything and swap it into my eb.
As for the upgrades i was thinking of just doing a mild cam. Everything else stock. Would that still work with the SD system or should i just look for the MAF system?
Thanks again.
__________________
  #5 (permalink)
Old 05-01-2008, 06:24 PM
terron78b is starting off with a positive reputation.
fi in eb
google ford fuel injection.com there is a lot of good imfo i have learn a lot from them
  #6 (permalink)
Old 05-01-2008, 09:20 PM
RCrawler's Avatar
If you have access to a welder, you can make one very easily with some
1/4"x 3 flat bar.
Leave your bellhousing mounted to your original engine. Bolt the clutch bracket to it and then make a pattern to tie into one or both of the adjacent bellhousing bolts and have it welded to the bracket. I can get a couple of pictures of mine if you need to see.
If you plan on even a mild cam, I would search specifically for an SEFI engine, either SD or MAF. The HO MAF engines have been picked over pretty good, so you will probably have better luck looking for both. You can always do a conversion to MAF.
Jason
__________________
  #7 (permalink)
Old 05-01-2008, 10:06 PM
Jason I think i have an idea of what you described for the braket. A picture would be great whenever you have time. I'm in no rush.
This hole EFI, roller block set up is going to be my summer project. That and getting some paint sprayed on the body. I figured i would do the engine while the body was off the frame.
Clint
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
