04-30-2008, 02:20 PM
You are doing the test with the doors shut correct? Your late model should have a courtesy light relay you can unplug to kill all the domelight circuit. You could try pulling that and see what happens.
Also, I almost forgot. Since you have a late model, you are going to have to wait 10 to 15 minutes before you can do the draw test. Your model has a battery saver relay and a accessory delay relay that powers everything up for awhile after you pull the key and shut the door.
__________________
Dave F
1989 F250 XLT Diesel
