Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-29-2008, 06:07 PM
beachrat is starting off with a positive reputation.
I have no brakelights,4 ways,or power at the fuse
I have an '87 Bronco with a carbed 5.8 in it.
My brake lights and 4 way hazards aren't working,so I took a look at it today.
I wasn't getting any power at the brake light switch,so I checked the fuse.It looked fine,but I changed it anyway and there was still nothing.
I pulled the fuse out and checked for juice at the terminals in the fuse box,and there is none on either side.I looked at a schematic in the Haynes manual and all the wires that are supposed to be there are correct and look fine.
Where do I start looking to find out why there's no power going to the fuse?
(It's the #1 20amp fuse in this truck)
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-30-2008, 12:21 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I would pull the fuse box and see if you can take it apart and see what the problem is. You could also find another fuse that is hot all the time(such as the cigarette lighter fuse), pull it out and find the hot side with the fuse out. Buy a fuse tap, slip it over the correct hot leg of the fuse, and then jump this over to another fuse tap onto the brake fuse.
This is how the fuse box is made inside. It has a buss that ties all the hot all the time fuses together, and another buss that ties all the key-on fuses together.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 04-30-2008, 05:23 AM
Thanks Dave.
A guy on another site said that the Y should be hot and coming from a fusible link off of the starter relay,so I'll try to trace it first.
If it doesn't work out,I'll have to jump it.
I'd like to try to keep all the wiring stock so I don't burn the thing to the ground,which is the way my luck usually runs.
  #4 (permalink)
Old 04-30-2008, 03:19 PM
87 XLT is starting off with a positive reputation.
Sounds like this is wired the same as my 87 Ranger.
If thats the case, the fuse link on yours is spliced to fuse 1 AND to the ignition switch and your truck would'nt run if the fuse link was blown.
Take another look at your wiring diagram.
  #5 (permalink)
Old 04-30-2008, 07:16 PM
Well,I fixed it today.
I traced the yellow wire from the firewall,to the starter relay and found a break in it.
Replaced most of the length of it and I'm back to normal.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
