Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-29-2008, 03:06 PM
philmo418 is starting off with a positive reputation.
Cold but not Cold Enough
Hello All,
I have a 92 EB Bronco with the 5.8. Since another summer is closing in here in Texas I was wanting to get my AC right. On normal AC It does blow cold air, just not hard enough or cold enough to help on the hottest days. Anything over 95 it is cooler to use the 2/60 air. Also, when I try to use MAX air it seems to work for about 20-30 seconds then nothing. No air at all.
Philmo.
  #2 (permalink)
Old 05-16-2008, 01:23 AM
bustech81 is starting off with a positive reputation.
How many miles on this thing, what are you running for head pressure. Usally a/c that craps out in high ambients is condenser airflow problems,(fan clutch). when on max setting, where does the air go in 20-30 seconds? does the fan stop running, or come out the defrost vents?
  #3 (permalink)
Old 05-16-2008, 07:20 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Also, check for a dirty evaporator core, dirty condenser, weak fan clutch, etc....
The only difference between MAX and normal A/C is the recirculation door. That should have little affect on airflow although in MAX, the flow is generally stronger.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 05-23-2008, 04:14 PM
Thank You
Thanks for the replies. Sorry I have been out of pocket for a while. I will look into your suggestions.
Phil
  #5 (permalink)
Old 05-24-2008, 11:43 PM
fordman1090 is starting off with a positive reputation.
it would also help to have some outside temp reading and vent temp readings. Does it cool better when you get on the hiway? did it slowly get worse? or was it just all the sudden it stopped cooling?
as for it totally stopping on Max A/c, can you hear the blower still running or does it shut off the blower?
A little more info will help us.
__________________
93 F150 XL SC SB, 300 I6.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
