Banks Technicooler tubes
I just got off the phone with Banks. I was getting a quote for just the tubes, cold side and hot side. He talked me into hoses and clamps. So to sum it up; 2-3X3 hoses, 2-3X3X4 hump hoses, 8 hose clamps, hot and cold side tubes all for $125.29.
Does this sound reasonable?
I did not get their ram intake Y-pipe because I know they want a ******** for that.
I am going this route because due to my living situation I cannot get access to tubes and a welder. This would be quick and easier for me. I have the 6.0 cooler and the early '99 Y-pipe already.
on
1 Post
Neal your still going to have to fab. Even with the bank y-pipe the tubes need to be shortened for height some. Using the Early 99 y I think your going to run into even more problems cause I think the banks unit extends farther over the valve covers. here is a link to rtxcoon's 6.0 install. he had to trim for height
I can't look at pics on you-tube or webshots or similiar accounts due to security issues here at work. So when you say shorten for height can I just cut or do they need to be welded. I can cut.
And when you say the banks y-pipe extends over the VC I understand that but they still have to be modified? I would think the pipes should be plug and play if you have all of their stuff.
To fix the part of the y-pipe that doesn't hang out over the VC enough I could get a piece of pipe from a mufler shop couldn't I?
on
1 Post
DSC00018 pictures from friends & fun photos on webshots
on
1 Post
i think the 6.0 cooler inlets are in different locations than the banks or the stock 7.3? i could be wrong though. the tubes are just 3 inch round pipe, you can use a rubber connector to join them together if you need to cut and adjust. i did no welding on mine either and all of my piping is customized.
how soon are you in need neil? i have a bunch of pipe still and some clamps. i can see what i have, i hav eno clue what shipping would cost though.... when is the next time you are up here on work?
I had to cut 5" out of one pipe and 6" out of the other....keep in mind I didnt say shorten, I said "cut out" and then reweld in the riser sections of the piping from the intercooler....basically the reason for this was because I had to mount my 6.0 intercooler higher than normal due to the cross tube on my reverse shackle kit...
to the OP, dont worry about the fab, if you measure and re-mearsure, then cut your pipes, any local competent muffler shop should be able to reweld them back for you at a pretty decent price...the trade off is that you ruin that pretty grey banks powder coating...LOL!!!
my webshots album on the install pretty much shows everything I did to get the cooler mounted and cutting of the pipes if you can access them from somewhere other than your work...
Also are those pipes aluminum or steel? I have a buddy that has a welding shop back at home I may be able to use. It is just a logistics thing with me being in Erwin and all my tools in Roane county.
thanks
