2005 F250 6.0 transmission slip (reverse)
When in reverse and the transmission is under a load i am getting a slip somewhere. Also shifting into drive or reverse the transmission is slow to engage and sometimes bounces in and out of gear until it sets. Any feedback would be appreciated. I have heard that these weak transmissions have a reverse clutch. Can the torque converter slip in reverse when it seems to work well going forward?
Thanks SOB Racing
Thanks SOB Racing
These are not weak transmissions.
Yes, they have a reverse clutch. Somewhere out there there may be a transmission that doesn't have a reverse clutch, but I'm not aware of one.
The torque converter doesn't know if the trans is in reverse or drive. It does exactly the same thing in drive or reverse.
It sounds like you have one or more solenoids that are sticking. The most common cause of sticking is contamination. That can happen from ATF that is to old, or using the wrong ATF. Sometimes it just happens for no apparant reason.
It's best to flush it with a heated fluid exchange machine. The TorqShift has a thermostat. The trans needs to be at least 170F and kept that warm durning the fluid change or it will recirculate the old fluid instead of pumping it out. I've seen instructions on the net to do it yourself, but I haven't tried it and I don't know where to find them.
Mercon SP is the only fluid designed and approved for the TorqShift. The aluminum trans filter canister under the right front side of the truck (FT-145) takes a 22MM socket and generally needs an impact wrench to get loose without bending/breaking the bracket.
Here's a thread with some info: www.ford-trucks.com/forums/734984-05-external-tranny-filter-removal-install.html
The 'home-flush' procedure is in the 6.0 Tech Folder. I had the dealer do my trans flush at 20K and have just drained the pan and changed the FT-145 since then. Yours is definitely overdue!
Kepler4: When I changed the my FT-145 I used about a quarter of a quart of Mobil 1 syn tranny fluid, dont remember if it was SP or not. Will this be a problem?
According to the mobil website Mobil 1 syn trans fluid is NOT mercon sp here is an excerpt
Mobil 1 Synthetic ATF
Synthetic Automatic Transmission Fluid
Outperforms conventional ATF and meets General Motors' Dexron® III and Ford's Mercon® and Mercon® V requirements. Also recommended for Chrysler automatic transmissions.
Fully synthetic formula provides outstanding resistance to oil breakdown and deposits under severe duty and high temperatures.
Helps extend transmission life through excellent durability and protection.
I would not use it in place of Mercon SP which I understand is synthetic if you have a tranny problem and they find you used the wrong fluid you wouldn't have a warranty.
Transmissions are EXTREMELY sensitive to having the right fluids. Always be sure to use the right stuff.
I'm getting mine flushed tomorrow. I'll let you know how it turns out.
