Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-29-2008, 01:27 PM
Pwarrenn's Avatar
Pwarrenn is starting off with a positive reputation.
Is there a Bigger Wheel/Tire combo that will give me the Same MPG as the Stock 18
would like different wheels on my 2008 but do not want to give up MPG..Am I stuck with the Stock set up?? I have 18's with the 275 conti's I think..
__________________
08 F350 XLT,CC,LB,SRW,6.4,4X4,3:73
68 F100 Ranger,2WD,360,C-6,3:25
65 Mustang,Supercharged 302,T-5,3:50
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-29-2008, 04:18 PM
NJF350SD is gaining momentum as a positive member of FTE.NJF350SD is gaining momentum as a positive member of FTE.
Circumference is going to be your main key. You can change your wheel/tire combination, so long as you don't change the overall circumference of the tire, your effective gear ratio will not change and thus you could retain the same fuel mileage.
Now I said "could". For example: If you go to a 20" rim and a lower profile tire to fit with the circumference idea, you would be likely adding significant rolling mass to your wheel/tire combination which could [would likely] result in lower fuel economy from the added power needed to rotate the additional mass.
__________________
Chris
2008 F350SD CC PSD Short Bed
2000 F350SD CC PSD Dually - Sold
1995 F350 CC PSD Long Bed - Traded-In
1987 F250 STD Cab - Gasser - Sold
  #3 (permalink)
Old 04-29-2008, 06:00 PM
texastech_diesel's Avatar
texastech_diesel is gaining momentum as a positive member of FTE.
Check the Revs per mile on the tire. Different tire with the same revs will run mostly the same.
You can go by circumference if you want I guess. For example: Go to the Nitto website and open the specs on one of their Grappler tires. It will list an actual circumference, so that's a very rough way to guesstimate similar size between different width/aspect ratio/wheel sizes.
__________________
Wreck em Tech - Go Red Raiders
My Farmall pulls harder than your Honda. Fear the PSD.
  #4 (permalink)
Old 04-30-2008, 09:25 AM
wwb wwb is offline
wwb is starting off with a positive reputation.
Tall, skinny, & hard (high pressure) = good mpg
Short, wide & soft = poor mpg
Tall, but wide = in between
Your choice.
  #5 (permalink)
Old 04-30-2008, 02:58 PM
diesel_dan's Avatar
FTE Addict
diesel_dan is gaining momentum as a positive member of FTE.
That's been the opposite of my experience (mostly high performance cars). The rubber and structural components of the higher ratio tire (taller sidewall and perhaps wider tread) outweigh the larger diameter alloy wheels (with a lower aspect ratio tire) -- especially our forged Ford rims. Going to a 20" wheel (ala: Ford's 20" tire/wheel combo), would increase your circumference and diameter slightly, but should weigh less overall, and with reduced rotating mass, likely increase your mileage, albeit only slightly. Your right foot has far more to do with mileage than just about any other change you could make...
I haven't actually weighed the two, so this is an extrapolation based on past experience. I'd be interested if you could find someone with the 20's set up and pop a wheel/tire off and weigh yours back-to-back. It's important to use the same scale, same temp, etc. to have a direct comparison.
If you do this, let us know what you find -- those 20" take-offs I see advertised may jump in price with these fuel prices...
__________________
'07 F350 SRW SC/LB, 6.0 PSD/Auto, 4x4 -- SuperHitch w/ custom 16" SuperTruss, Tork Lift Camper Tie-Downs, Rancho RS 9000X Shocks, Air Lift Air Springs, BFG A/Ts 305/65/18E, GO Industries Mud Flaps.
'00 Expedition 5.4 4x4 Eddie Bauer -- Bone Stock
  #6 (permalink)
Old 04-30-2008, 05:49 PM
duffman77's Avatar
duffman77 is starting off with a positive reputation.
If you spend any kind of time on this site, one thing you will learn is that 2 things tend to be present on trucks with poor MPG: Lifts and big tires. Dont alter your tires if you want MPG.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
