Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-29-2008, 11:06 AM
fyrmn681 fyrmn681 is offline
fyrmn681 is starting off with a positive reputation.
Help please... Code 171 and 174
I've got a 05 FFV taurus 3.0 . It is giving me these lean codes and starting to develop driveability problems. Worst time is morning cold starts. It will start hard, maybe 2-3 tries, then might die a couple of times getting out of driveway.. It is running on E85. It's symptoms are similar to the earlier problem it had before Ford Engineering could program the pcm correctly. Only no codes at that time. Since they recalibrated it, it has been fine till now. After the car gets going, It seems fine except I think the gas mileage is down. Checking for sure on this fill-up.
I have replaced the air and fuel filters. Cleaned the MAF sensor. Fuel pressure seems to be fine. Had 80# when dead heading the pump. Scan tool read in low 40's while running. I haven't been able to do a running test with my gauges yet because of a clearance issue with an engine mount. I have also checked for vacuum leaks with a can of carb cleaner and can find nothing. Any help would be greatly appreciated. THANKS
  #2 (permalink)
Old 04-29-2008, 11:26 AM
Afterthought
I have read some of these other post with people having cam pos sensor and synchro problems. I do get a squeaky noise especially in below freezing temps. I had been blaming that on the altenator. Do not have the 340 or 1309 codes however. Any Possibilities?????
  #3 (permalink)
Old 05-16-2008, 10:50 AM
I don't know if I stumped everyone or if it is because this section isn't seeing alot of traffic but I thought I would post an update. I switched it back to regular gas and it ran fine. Went back to E-85 after one tank of gas and it still starts and runs fine. ??????????
  #4 (permalink)
Old 08-17-2008, 10:22 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman is starting off with a positive reputation.
i would say vacume leak, this is a common thing in the 5.4 forum, double check for vacume leaks.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
