XE258hr cam
XE258hr cam
I put this cam (XE258HR) in my 302 setup with eddie 1.90/1.60 valve heads, dualplane intake, small tube headers, and 600cfm carb in destop dyno 2000 and got some awesome torque numbers down low at flywheel. I figured this cam would be a great upgrade for a 302 powered truck especially making it easier to spine the tires...what you guys think of this cam? If any of you got the destop dyno stuff try this cam out with a mild setup like I had and see if it tells the same story. My dyno was a cheap/free download I got from somewhere I can't remember. I got like 350 hp and like 380-390 tq on my dyno with 9.0 compression
on
I'll run the numbers on my copy later, but I suspect your copy is being painfully optimistic. Exactly what Edelbrock heads are they(part #)? They have too many versions and they all flow different numbers. FWIW I don't see a carburated 302 making anywhere near that much TQ at what I would consider to be low rpm.. under 3000rpm.
they are the 60229 RPM versions with no egr stuff (http://www.edelbrock.com/automotive_.../flow_data.pdf).
I beleive the torque peaked at like 4000rpm but there was at least 340 lbs of torque at like 2500rpm from what I remember, I'm on a different computer right now or I would tell you exactly what it said but I will be later today and I'll give you the info it told me
Joel Cassell
18
05-11-2018 11:31 PM
htownoag
19
02-28-2016 11:18 AM
AJWACJ
19
01-03-2012 11:44 AM
DasCheckers
02-07-2009 12:27 AM
