Replacing oil pump in 302 - Ford Truck Enthusiasts Forums
Old 09-08-2001, 06:53 PM
block0 block0 is offline
block0 is starting off with a positive reputation.
I have a 1987 302 EFI engine in a Bronco (same year) that recently lost oil pressure. It had been taking longer and longer to come up to pressure lately (the past few months), and finally I went out to start it and had no pressure. So, I need to replace the pump. My Haynes manual says I have to remove the upper intake manifold and take out the radiator to raise the engine up a bit, but I can't see why either of these need to come off? Also, does anybody have any other advice for pulling the oil pan? Thanks.
Old 09-09-2001, 04:18 PM
david_mirabile david_mirabile is offline
david_mirabile is starting off with a positive reputation.
if you have a fan shroud remove it. then take the bolts loose from your motor mounts. then use a jack and a timber and gently jack the front of the motor using the harmonic balancer as the jacking point. i don't see why you would have to pull the intake.
Old 09-10-2001, 12:20 PM
loudfords's Avatar
loudfords loudfords is offline
loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.
Engine help 51 F3 owner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 08-06-2014 03:40 PM
No start after injector work ryder1541 1999 - 2003 7.3L Power Stroke Diesel 19 08-24-2013 11:09 AM
Oil coming out the Exhaust...Bad Turbo? Injectors garsm 1999 - 2003 7.3L Power Stroke Diesel 2 07-31-2011 05:21 PM
302 low oil pressure - in Explorer 2001 EB SoNic67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 23 11-17-2010 04:51 PM
Oil Pressure on 1994 F150 busby Southern Region 1 09-07-2010 10:31 PM
Tags
1977, 302, 79, block, f150, ford, lose, lost, oil, pressure, pump, replace, replacing, small, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
