Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-29-2008, 12:59 AM
truckdog62563's Avatar
truckdog62563 is gaining momentum as a positive member of FTE.
A Great Source For New Big Truck Wheels
I've got a thread going over on the 1948 - 1960 page about a conversation I had today with the owner of American Wheel Specialst, LLC. in Pasco, WA. This company can supply new tubeless 19.5" wheels that use our big truck 5 lug x 8" circle bolt pattern. They can also supply reconditioned 20" lock ring wheels for guys that want to retain a stock configuration. So go over and check it out. Stu
__________________
Stu
'52 F-3 Marmon-Herrington V-8
'52 F-3 Marmon-Herrington I-6
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-29-2008, 01:24 PM
petey shoes is starting off with a positive reputation.
truckdog, are you sure center hole on m-h is 8 inch? my 42-450 only has 6 inch. these rears are(i believe) heavier than f-3. i just wonder why lighter truck has bigger axles? pete
  #3 (permalink)
Old 04-29-2008, 01:55 PM
The bolt pattern on just about all the old Ford big trucks of the late 30s through early 50s was 5 lug on an 8" circle. That figure is determined by placing a tape on the outside edge of one lug and measuring across the wheel, past the second/nearest lug, to the middle of the third lug. That measurement will be 8" on your truck. The really early trucks, back into the mid or early 30s, had 5 lug on a 6 7/8" circle. That bolt pattern was used extensively on WW2 military vehicles and post war Dodges Power Wagons.
The center bore/hole of our wheels is 5 7/8". That closely matches your 6" measure. Stu
__________________
Stu
  #4 (permalink)
Old 04-29-2008, 02:06 PM
stu, you are absolutely right, i was thinking of center hole dimension. never too old to learn and listen!!! now i'm going outside and hit my head on something really solid! pete
  #5 (permalink)
Old 04-29-2008, 03:34 PM
Don't hurt yourself. It's not worth it. Stu
__________________
Stu
  #6 (permalink)
Old 04-29-2008, 04:13 PM
small bump, no pain. i'm feeling much better now! pete
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
