Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 04-30-2008, 02:01 AM
tbone91 is starting off with a positive reputation.
Is possible you have a slow fuel leak somewhere?
Also, do any neighbors own diesel vehicles? Maybe they figured out "he won't notice a little bit missing now and then"...
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #17 (permalink)
Old 04-30-2008, 02:33 AM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Quote:
I think my Cummins is pretty tough but I don't think I can piggy-back a couple-three semi trucks on it.
Maybe one at about 25 mph. until I break my clutch, trans.,X-case or rearend and I think it would off-set any fuel mileage gains. Actually simply the weight of the magnet might be too much all by itself.
Sure, but think of all the fuel you will be saving in the center of that black hole.
To the original question, did this happen overnight? If your fuel filter is a year old, I think you have little to loose in replacing it just in case.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #18 (permalink)
Old 04-30-2008, 12:28 PM
Joetravelall is starting off with a positive reputation.
A new fuel filter is next on the list. It will be changed this weekend if I don't go camping with the Scouts. As for neighbords with diesels. I know of one just a couple of houses down and I don't thing he is the problem. No leaks I have seen signs of or smells. No drips on top and no puddles on the ground. Every once and a while I get a drop of oil out of the bellhousing drain tube, but that is it. I am having an issue with my transmission during wet weather I posted in the Clutch,Transmission, Differential, Axle and Transfer Case fourm, but I don't think it is related, but you never can tell. As for over night yes and no. It did happen rapidly my milage went down to 7 to 9 mpg and has come back up some. It has been getting better but it still has a few more mpgs to go. It all happened over the last year.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
