351 4-bolt main??
351 4-bolt main??
I am interested in buying a 351 for racing purposes. I was wandering did ford ever make a 351,351M with 4-bolt mains. and if so when. also, I will probably be turning this engine in the neighborhood of 6000 RPM. Would I definitly need a 4-bolt main to stand up to this.
A properly built Ford motor, balanced, blueprinted, etc. will handle 6000 RPM on 2 bolt mains very well. Remember, we're not talkin about those "other" motors that need 4 bolt mains and steel cranks to turn the Rs Ford racers have been doing it for over 40 years.
Nathan
351 4-bolt main??
If you want a 4-bolt main Windsor, you can buy them from SVO Ford
http://oemfordparts.com/partslist.asp?CategoryID=12
Part #: M-6010-S351 cost about $1700 US.
A cheaper alternative would be to use a stock block with a "main cap girdle" which ties all the main caps together to prevent "cap walk". This setup will easily handle 7000 RPM.
RCC
RCC
75Three90
07-28-2015 10:53 AM
TMI
07-06-2014 09:21 AM
79-F350
05-03-2014 12:23 PM
