351 4-bolt main?? - Ford Truck Enthusiasts Forums
351 4-bolt main??
Old 07-25-2001, 04:04 PM
DrFord DrFord is offline
DrFord is starting off with a positive reputation.
351 4-bolt main??
I am interested in buying a 351 for racing purposes. I was wandering did ford ever make a 351,351M with 4-bolt mains. and if so when. also, I will probably be turning this engine in the neighborhood of 6000 RPM. Would I definitly need a 4-bolt main to stand up to this.
Old 07-25-2001, 07:13 PM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
351 4-bolt main??
Ford did make some 351C blocks with 4 bolt mains, but no M blocks. Good luck finding a 4 bolt C block that is not in a car being sold for lottery size $.
A properly built Ford motor, balanced, blueprinted, etc. will handle 6000 RPM on 2 bolt mains very well. Remember, we're not talkin about those "other" motors that need 4 bolt mains and steel cranks to turn the Rs Ford racers have been doing it for over 40 years.
Nathan
Old 07-26-2001, 11:47 AM
swenson swenson is offline
swenson is starting off with a positive reputation.
351 4-bolt main??
Are all 351W's 2-bolt mains?
Old 07-26-2001, 06:18 PM
460v10 460v10 is offline
460v10 is starting off with a positive reputation.
351 4-bolt main??
Yes.
Old 09-20-2001, 03:56 AM
albatross albatross is offline
albatross is starting off with a positive reputation.
351 4-bolt main??
You can get 4 bolt mains clevelands in Australia for about $200 USD. I think the company is called netengines.com.au or something similar. Do a search in OZ only and they will turn up.
Old 09-23-2001, 05:19 PM
rc351w rc351w is offline
rc351w is starting off with a positive reputation.
351 4-bolt main??
If you want a 4-bolt main Windsor, you can buy them from SVO Ford
http://oemfordparts.com/partslist.asp?CategoryID=12
Part #: M-6010-S351 cost about $1700 US.
A cheaper alternative would be to use a stock block with a "main cap girdle" which ties all the main caps together to prevent "cap walk". This setup will easily handle 7000 RPM.
RCC
Old 09-24-2001, 01:13 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
351 4-bolt main??
1972 351c HO question mustang81 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 07-03-2015 02:04 PM
79 F250 351M to 300 question apachetech Engine Swaps 7 03-14-2015 06:49 PM
Oil leak location iDENTification Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-20-2014 04:22 PM
351c or 428? tracytruelove 1961 - 1966 F-100 & Larger F-Series Trucks 49 08-08-2013 12:11 PM
351 ford cookieman69 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 10-28-2009 03:57 PM
Tags
351, 351c, a351, block, blocks, bolt, cap, engine, ford, girdle, identifying, m6010, m6010s351, main, svo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
