Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 05:50 PM
Farmall05's Avatar
Farmall05 is starting off with a positive reputation.
r 12 or 134a
I have a 94 f250 and the air needs recharged but I ran into one problem I dont know what is/was in the sistem there is nothing under the hood that said eather way how do I tell
__________________
Farmall05
94 f250
7.3 5 speed
2 wd
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 06:03 PM
lsrx101 is gaining momentum as a positive member of FTE.
Quote:
If the service ports look a bit like tire valves and have external threads for the cap, you have an R-12 system. There will also be a pressure releif valve on the hose manifold at the rear of the compressor.
If the service ports look more like male air hose fittings (they're quick connect fittings) and have internal threads for the cap, you have an R134-A system. There will also be a 2 wire switch on the compressor hose manifold or on the high side line going to the condenser.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #3 (permalink)
Old 04-28-2008, 06:12 PM
Farmall05's Avatar
lsrx101 thank you I will have to go check it out now
__________________
Farmall05
94 f250
7.3 5 speed
2 wd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
