Quote:
Originally Posted by joe blow
Is it safe to ASSUME that if my head gaskets were done last year (by a ford dealer under warranty), that the dreaded heads will last and not blow again?
Like alot of things that depends. Main thing it depends on is if the repair was done correctly. You can still blow the heads even if it was done correctly and without a tuner(contrary to alot of popular opinions on the anti-tuner regime) just depending on how you drive. Now if you were to have studded the head and had correct installation and repair of the headgaskets then unless you start adding insane amount of horsepower(from by 600 on up) you should be fine with stock gaskets and new or machined heads and not have to worry one lick about them. If it was fixed with bolts then that concern should always be in the back of your head and determine on how you drive it(ie let it get up to normal operating time especially before you drive it like you stole it).
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
