Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-16-2008, 09:47 AM
buckweet1980 is starting off with a positive reputation.
I have somewhat of the same symptoms.. I purchased my truck last year in the summer time used and every once and a while the cooling fan would come on. Mainly when you were stopped at a light and accelerating. It also would come on when pulling. It would come on for about 1 minute and go off. I get the 'whistling' noise coming from my degas bottle under normal load, and the truck uses some coolant. I have to put a gallon in about every month or so. I don't have any signs of white deposits on the bottle.. I'm kind of torn whether its the head gaskets or maybe a faulty EGR.. I'm going to do the EGR delete soon, I hope that will help me know..
BuckWeet
  #17 (permalink)
Old 05-16-2008, 05:36 PM
joe blow is starting off with a positive reputation.
Is it safe to ASSUME that if my head gaskets were done last year (by a ford dealer under warranty), that the dreaded heads will last and not blow again?
So far so good. I am starting boating season again..........
  #18 (permalink)
Old 05-16-2008, 06:32 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Quote:
Like alot of things that depends. Main thing it depends on is if the repair was done correctly. You can still blow the heads even if it was done correctly and without a tuner(contrary to alot of popular opinions on the anti-tuner regime) just depending on how you drive. Now if you were to have studded the head and had correct installation and repair of the headgaskets then unless you start adding insane amount of horsepower(from by 600 on up) you should be fine with stock gaskets and new or machined heads and not have to worry one lick about them. If it was fixed with bolts then that concern should always be in the back of your head and determine on how you drive it(ie let it get up to normal operating time especially before you drive it like you stole it).
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #19 (permalink)
Old 05-17-2008, 12:48 AM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
Quote:
Great advice Tex!
FYI:
Common Causes for Puking / Overheating
Thermostat
Coolant Temperature Sensor
Oil Cooler plugged or leaking
EGR Cooler leaking
Blown Head Gaskets
Clogged Radiator (air side)
Water pumps fins are split where they go around the shaft
They only spin for a while and when they get hot the spinning will slow down. An easy way to check for this problem is pull the hose off the degas bottle from the intake it should pump the same amount out hot or cold. This can make your engine puke if it is your problem.
Some suspect a collapsed radiator hose
Injector cup
Glow plug cup
Cracked head
http://www.thedieselgarage.com/forums/showthread.php?t=68584&page=2
Common Root Causes - turbo vanes stuck or warped heads (early on there were some torquing problems)
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #20 (permalink)
Old 05-20-2008, 03:04 PM
mackdog is starting off with a positive reputation.
ya..just drinking coolant, its dry under the hood, no smoke or anything.radiator cap looks clean
__________________
1992 F 250 4x4 5 spd 7.3 diesel. 255,000 miles and counting. Tough country suspension, 33" tires.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
