Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 06:00 PM
6.9ford84(smoker) is starting off with a positive reputation.
6.9 needs power!!!!!
i have a old 6.9 and am looking for ways to get as much safe power with not much money needed. Thanks
  #2 (permalink)
Old 04-28-2008, 10:36 PM
1994diesel's Avatar
1994diesel is starting off with a positive reputation.
you could do an air ram intake, just direct the air from the outside of the truck, search the form for that and you can get pics of what other people have done for ideas.
__________________
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, pump turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #3 (permalink)
Old 04-28-2008, 11:25 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
The cheapest way to get the most power is to look for a second hand turbo kit. I got an incomplete kit for $200 (had to fab the downpipe and crossover pipe). But usually they are in the $500 range. If you are patient the right deal will come along.
A ram intake will help, but to really make a difference that will let you hold those long hills on the highway, a turbocharger is the only real significant difference you are likely to find.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #4 (permalink)
Old 04-29-2008, 01:06 PM
tbone91 is starting off with a positive reputation.
One thing that's easy to overlook is the air cleaner. Make sure it's clean...
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #5 (permalink)
Old 04-30-2008, 05:29 PM
ok, air cleaners clean and cut the big baffle out of it. any other quick fixes???
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
