Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 04-29-2008, 02:31 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Dodge/Cummins View Post
Those swap parts are expensive by MY standards.
I would go with the '94-'98.5 donor, no (or less) electronics to wory about.
The intercooled ('91.5-'93) are even simpler and lighter (I.P. is not nearly as big or heavy, but also not as good), cheaper donor, and the Bosch rotory I.P. is "tunable" with out any extra parts.
If your goal is BIG power the Bosch P7100 equipped '94-'98.5 is the way to go.
Minus the engine, I'm figuring about 3K total for the swap, including driveline mods and any misc extras that come along.
My goal isn't to make huge power numbers. I want something a little different. And I want to be able to run with some of the late model trucks. I'm tired of getting outpulled by newer trucks with twice the weight behind them. I've given a lot of thought to getting rid of my truck and getting something new(er). But I like my crewcab and I know what is wrong with it and all of its idiosyncrisies.
Jason
__________________
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
Missing your Prius, check under my tires...
  #32 (permalink)
Old 04-29-2008, 08:27 AM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
I did a Cummins swap into a 460 truck. Being 2wd it made things much easier. I just used the Dodge trans because I couldn't justify the cost of the adapter plate, and made my own motor mounts. Realistically, it wasn't all that bad, the motor mounts were the hardest part. The VE pump works fine for my needs, don't need insane power, just need enough to drag a few trailers down the road reliably.
To swap from a 460 gas to an IDI wouldn't be all that easy either, as there is a few things that have to change. The motor mounts for the 460 have to be gotten off the frame, the rad support is wrong and would need changed to get the bigger radiator on it. The trans from the gas motor won't work either, you will need it as well. Otherwise, it is all bolt up.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, 47RH auto with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #33 (permalink)
Old 04-29-2008, 10:22 PM
1994diesel's Avatar
1994diesel is starting off with a positive reputation.
THERE IS NO QUESTION THE CUMMINS IS WAY HARDER TO SWAP IN- it's not even close, just in case I wasn't clear about that. I just think there is a good chance you'll never have to take it back out.
I should be picking up the '94 this weekend, the owner is finally back from Wisconsin. I FULLY EXPECT it will treat me just fine! Got my fingers crossed that it's as good as it looks. If I can figure it out with my almost non-existant computer abilities I'll post some pictures when I pick it up.
GREAT!!! i think you will be satisfied, i am. best of luck to you, just check the turbo, it would suck if you drove it home and you found out it was bad.
__________________
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, pump turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
