Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 05:29 PM
GeneralSteve is starting off with a positive reputation.
92 diesel engine
I was wondering if anyone could tell me about the 7.3 idi diesel engine that is in the 1992 ford f250 diesel trucks?
  #2 (permalink)
Old 04-28-2008, 06:29 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
Well it is by factory a non turbo engine that uses a mecanical fuel injection pump with no computer to control the engine. There are not very many mods that you can do to the motor besides an aftermarket turbo which would be the biggest gain other than that the small modes would be injection pump, injectors, head studs for higher boost pressure with a turbo.
They run very well, they are somewhat noisy but I think it sounds good. They start easy providing that the glow plug system works well, good batteries, starter and power cables. No fuel leaks that could suck air into the fuel system and good pickups in the fuel tanks. Injectors are also much cheaper than you would find in a power stroke ($30 for these verses $200 or more with the powerstrokes) and are much, much easier to change. Overall this engine is probably one of the easiest to work on if it needs repairs. Most of the repairs could be done on the side of the road with limited tools. Most the parts are at the top of the engine and easy to replace because nothing is in your way compared to other newer trucks.
Are you familer with any other diesels at all or is diesel new to you?
Are you looking at buying one or is it one that you have purchased recently. If your looking to buy one, say so because these guys can give you good pointer on checking out the engine and components before you buy it. Good luck
  #3 (permalink)
Old 04-28-2008, 08:23 PM
tpolley is starting off with a positive reputation.
i just purchased a 92 f250 7.3 about a month ago. it has 186k on the frame the motor was replaced with a new "drop in" at 102k for unknown reasons. it is noisy when it's cold. when you start it in the morning it sounds like the earth is comming to an end but quiets up in 30 seconds or so. my first experience with any diesel was test driving this truck. i fell in love with it and bought it. it gets good gas milage on the highway, terrible g/m in the city. it has plenty of power and 4:10 gears give it respectible get-up.
  #4 (permalink)
Old 04-28-2008, 10:34 PM
1994diesel's Avatar
1994diesel is starting off with a positive reputation.
sounds like you made a good pick!!!
just what ford mega cab said, get a turbo, its the biggest bang for your buck.
__________________
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, pump turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #5 (permalink)
Old 04-29-2008, 01:12 AM
Thanks for the info. I have had itmfor awhile and i just want to get some more power out of it for fairly cheap.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
