Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 05:04 PM
94F250TD is starting off with a positive reputation.
Clutch Question
Hey guys i got a small question i just installed a clutch this weekend and now that it is in, it makes a machine gun sound when the pedal is all the way to the floor! what it sounds like is the fly wheel is hitting the bell housing. Is there anyway to adjust the clutch? It shifts fine but i cant press it all the way to the floor. O ya it a single mass flywheel.
Thanks guys
p.s. the ats downpipe sucks when changing a clutch i had to remove the whole exhaust system to get the tranny out lol o well its done now
__________________
1994 F-250 7.3L IDI Ext. cab lond bed ZF-5 speed ATS downpipe and snail to a full 4" exhaust home made intake to a cone filter Pyro and boost gauge on the A-pillar new pump and injectors she runs great!!!!
  #2 (permalink)
Old 04-28-2008, 05:38 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
Look at the clutch release fork. See if it is hitting the pressure plate when you push down in the pedal. What ever is hitting will have marks on it.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #3 (permalink)
Old 04-28-2008, 07:26 PM
symonds86 is starting off with a positive reputation.
my buddys did this we had to trim part of the cast aluminum in the bellhousing
  #4 (permalink)
Old 04-28-2008, 10:30 PM
BigJake86 is starting off with a positive reputation.
I'm thinking way back here but I believe when converting some of the dual-mass to single-mass flywheels the housing has to be modified, which sounds like what you are experiencing. My memory is vague so someone please chime in. Contact Carolina Clutch (forum sponsor) if you don't get an answer.
__________________
2001 Excursion Limited 4x4 7.3 DP Tuner & F5 23MPG
1999 F-250 SuperCab 2wd 7.3 6-speed STOLEN!!!
1993 F-350 2wd Dually 7.3
1986 F-250 2wd 6.9
  #5 (permalink)
Old 04-28-2008, 11:04 PM
catfish101's Avatar
I did several of the conversions but I never ran into a bell housing problem. That doesn't mean anything though. I just didn't see it.
__________________
  #6 (permalink)
Old 04-29-2008, 06:58 PM
thats what it seems like to me and maybe i will contact carolina clutch to see what there view is on it. i also have another question my release point is very far out i thought it was because i didnt have it primed well enough but after pumping it hundreds of times and driving it it still is way far out is there any adjustment for it?
__________________
  #7 (permalink)
Old 04-29-2008, 08:49 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
I will be doing a single mass flywheel conversion on a powerstroke 1995 diesel in about a week. I ordered everything from Valair in texas:
ValAir Inc - High Performance Clutches for Diesel Trucks
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
