04-28-2008, 07:07 PM
switch or wiring?
any of the above
many of the switches at the doors will be ground activated
a bad wire wire short to ground and you have light
start with the switch and if thats not it you will have to move on to the door contacts
do you have a timer on the lights that activates with the ext. door handle and key fob
if so this switch could also cause your problem
unable to advise on the location of any of these other switch locations
good luck
__________________
2003 bull 3.0 24v stock
1996 E-350 351
