Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 04:06 PM
jrwhitey_2000 is starting off with a positive reputation.
1985 ford f 350 4x4 dually diesel brakes
I am having a heck of a time getting the brakes figured out on this truck. I have put on new steel lines, rubber hoses, wheel cylinders, brakes, and master cylinder on this truck. The pedal will stiffen up, but will bleed off if I hold the pedal. I have tried bleeding several times and it doesn't seem to help. The brake light is on and I have tried to get the proportioning valve reset by cracking the lines open with no luck. The vaccum pump seems to be pulling vacuum, but I do not have a vacuum guage to check the exact reading. How do I know if it is just a stuck proportioning valve, booster, or what else do I look for? I am out of ideas.
  #2 (permalink)
Old 04-28-2008, 04:54 PM
Piffery1 is gaining momentum as a positive member of FTE.
1. If the proportioning valve is off center then you likely would not get very much, if any, flow when bleeding the brakes (to front or rear depending to which end the valve is offset). Pull the wire off the proportioning valve contact and see if the brake warning light goes out. If it doesn't, check the parking brake switch circuit. If the proportioning valve is offset, the you need to loosen the lines on the opposite direction. Sometimes you have to stomp the pedal pretty hard to get the valve to re-center. 2. When you replaced the master cylinder, did you make sure the adjustment on the pushrod between the booster and master cylinder was correct? Too short, the pedal goes too far down and may feel spongy. There should have been a little cardboard gauge included with the new master cylinder (or at least adjustment instructions). 3. Possibly a leaking booster, vacuum line or weak pump. 4. When you replaced the master cylinder did you bench bleed it in a horizontal (level) position? It's virtually impossible to get all the air out with the cylinder mounted because of its angle.
  #3 (permalink)
Old 04-29-2008, 05:53 PM
I had the same problem prior to replacing the master cylinder. I replaced it hoping to fix the problem to no avail. I have tried and tried to get the proportioning valve reset. Where do I crack the lines at? I have been cracking them at the master cylinder, should I try at the valve itself? I thought if the booster or vaccum pump was bad I would have stiff brakes. How can I check the vacuum pump and booster without just going out and buying parts that do not need replaced. I did bench bleed the master cylinder. Can I take the proportioning vavle of and reset it any way?
  #4 (permalink)
Old 04-29-2008, 07:18 PM
The easiest way is to open the bleeder ports at the wheel cylinders. I'd try opening the front bleeder port first. You probably only have to open one side (L or R). The "Brake" light should go out when the differential valve piston is centered (assuming no problems in its electrical circuit). You may have to push the pedal much harder than when bleeding to get the valve piston to move. You could probably do it on the bench using compressed air to move the valve piston and an ohmeter to determine centering. The resistance between the switch terminal and the valve body should be a short when off-center and open when centered. Some valves can be manually centered using a piece of stiff wire like a straightened paper clip but it depends on the particular type of valve.
  #5 (permalink)
Old 04-30-2008, 07:21 PM
I removed the valve and it is shot. The valve is seized bad. I went out and took one off of my old 79 f250. The valve is centered and the light is off, but I did not have anyone to help me bleed them, so I will rebleed the brakes tomorrow and go from there. I guess if this doesnt work I need to start looking at the vacuum pump/booster. How much vacuum should the pump be pulling? Thanks for the help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
