Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 02:36 PM
mainevent223 is starting off with a positive reputation.
how do i know if the solenoid is bad
i have a 73 f100 and i turn the key and nothing happens, i know that if the started was bad i would still hear the solenoid click in. is this solenoid bad or am i missing something because all my elecronics work except the engine doesnt do anything.
thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 05:18 PM
fmc400's Avatar
fmc400 has a good reputation on FTE.fmc400 has a good reputation on FTE.
One thing you can do is take the wire labeled 'S' off the solenoid. Then take a flat blade screw driver, and jump the big lug of the solenoid that connects to the battery, to the small post with the 'S' on it. The engine should turn over, or the solenoid should at least click.
If not, check the positive battery cable. Then check the mounting surface of the solenoid to make sure it's clean and tight. Then make sure you have a ground strap from the body to the block somewhere, and then finally check the negative battery cable. That completes the circuit. If that's all good and your solenoid still isn't making, then the solenoid is bad (or your battery is dead as a door nail).
  #3 (permalink)
Old 04-28-2008, 08:44 PM
no battery is good everything else works. thanks for that tip. i'll remember that one.
  #4 (permalink)
Old 05-01-2008, 08:31 PM
ruggerio is starting off with a positive reputation.
starter fuse blows
i have 2004 expedition-starter fuse keeps blowing when i turn key--30 amp---i heard if the signal wire is grounded it will blow fuse-is there anything else that is causing this?? email me thanks!! ruggerio@bellsouth.net
i currently put a 40 amp fuse in the place of the 30 amp--
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
