Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 02:39 PM
SWMO F-350 is starting off with a positive reputation.
Most Miles Out Of Original Injection Pump?
I was just wondering whom has gotten the most miles out of their original 6.9-7.3 injection pump? Mine has 160,000 miles and I'm debating on whether to replace it.
The 91 F-350 still starts and runs good but after recently replacing the injectors it still seems to be down on power.Should I try advancing the timing a little?
I went 900 miles over the weekend pulling my 25 ft gooseneck.Empty I only got 10 MPG and pulling a 7000 lb load with alot of wind drag it only got 6 mpg.The wind was blowing pretty hard.I usually get 1 mpg better than that.I'm in 4th loaded and some hills required 3rd gear.
  #2 (permalink)
Old 04-28-2008, 05:44 PM
1957F100 is starting off with a positive reputation.
I got 200,000 miles out of my IP before it started leaking really bad. I have since replaced it with a new one and turned up the pump a little.
__________________
1957 Ford F100 - 302 w/ C4. Work in Progress...
1993 Ford F250 4x4 - 7.3L Diesel, ZF 5 Speed
Mods - Soup Bowl Removed. Hypermax Cowl Air System Installed. Autometer Ultra Lite Gauges. 4" Straightpipe to 5" Stacks. SouthBend Clutch. Cowl Hood. Custom Paint Job.
  #3 (permalink)
Old 04-28-2008, 05:55 PM
symonds86 is starting off with a positive reputation.
mine was 350,000 then i swapped in a turboed 7.3 but i put the old pump on the test bench at college and it was still strong it outlasted my motor
  #4 (permalink)
Old 04-28-2008, 06:02 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
As for changing the injection pump, if it works fine I would leave it alone or keep as a spare. I purchsed a core real cheap off ebay $35 and Im going to have it rebuilt soon. I am then going to put the rebuilt one on and keep the one I pulled as a spare (I keep all sorts of spare parts with me in the truck along with the tools to change them) So then if it does go, I can change it wherever Im at and keep going if it fails 800 miles from the house. Besides, who keeps one of the injection pumps in stock anymore if yours does fail.?! I just don't trust that little injection pump with all them percision moving parts that could fail at any moment that you can't fix on the side of the road.
Right now mine has 25,000 miles on it or more with no trouble. I don't know how long its been on cause I have only had this 1993 7.3 truck for a year now with 189,000 miles. It looks fairly new or rebuilt cause it clean and not factory painted as the motor is.
  #5 (permalink)
Old 04-29-2008, 02:13 AM
Dodge/Cummins is starting off with a positive reputation.
Your mpg and power loss could be only the switch to ULSD. I might sound like broken record but it could be the case.
  #6 (permalink)
Old 04-29-2008, 02:30 AM
George D.'s Avatar
George D. is starting off with a positive reputation.
Quote:
I would agree.
Also something as simple as a change in wind direction from normal could cause a 1 MPG loss or grater.
I have about 220,000 on my original IP I'm on my second set of injectors had one leaking so replaced them all while I was there and will probly rebuild then as spares or if I can figure out whats so special about DPS stage 1s
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #7 (permalink)
Old 04-29-2008, 02:38 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Quote:
If you get a straight answer, I'd like to know too.
I had about 210,000 mi on my original IP when I replaced it.
Jason
__________________
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
Missing your Prius, check under my tires...
  #8 (permalink)
Old 04-29-2008, 10:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Visually I can tell you there is no pintle sticking out of the nozzle on DPS Stage 1 injectors like there is on stock injectors.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
