Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 12:47 PM
REDNECK_MOTORSPORTS is starting off with a positive reputation.
Exclamation Huge Lift For Small Bronc
MY COUSIN GOT A 77 BRONCO AND WANTS TO LIFT IT AROUND 9" OR SO, WE DON'T LIKE BODYLIFTS AND HE DOESN'T WANT TO BUILD HIS OWN. IS THERE ANY KITS ON THE MARKET? WE CANT FIND ANY...PLEASE HELP
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 10:45 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Skyjacker makes a 9" coil for the F series, which will fit the Bronco. For the rear, you could go with a 5.5" spring and a 3" block (wheel hop is going to be bad). Or you could go with a 5.5" coil and drop the coil tower down. There are no "kits" available for the Bronco.
You will need some extensive work with the steering and suspension geometry to get it to steer. With that much lift, I would suggest a drop pitman arm, and a tie rod over, along with leveling the track bar as close to stock as you can. You will also need some radius arm drop brackets.
What are your plans for this Bronco? Are you lifting it that high just to fit large tires or do you plan on wheeling it? There is nothing wrong with a properly installed body lift. I have wheeled mine with a 2" body for many years. It would get you to the lift you want and still make it driveable.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
